Power steering swap- steering column modifications?
Old May 25, 2011 | 02:45 AM
Handegard's Avatar
Handegard
I have seen referances to three ways to go about the power steering swap-
Bendix gear. No.
Ford gear with later column
Ford gear and modify stock column.... What is involved here? It looks like the flange that bolts to the rag joint at the gearbox may be welded onto the shaft. Can I just cut the welds and shorten the shaft? Then weld it back on?
Or is there some other differences? Like angle?
Thanks! Trying to order everything I need to finish the truck this week. (order the parts this week, not finish
Old May 25, 2011 | 04:15 AM
jowilker's Avatar
jowilker
Chris, Getting a newer shorter shaft column with the correct tranny shift match might be the simplest way to go.
The newer donor column has a different cuff at the dash that longer bolts overcome, but is almost plug & play.
3spd columns can be the trickiest to make fit by cutting.
John
Old Jun 20, 2011 | 02:18 PM
Handegard's Avatar
Handegard
I'm still curious what is needed to modify the shaft.
Do I just remove the flange, shorten, and re-weld?
I'd rather re-use this column, A) it's original and B) I can't find a column for power steering and a manual transmission...
Old Jun 20, 2011 | 09:16 PM
HIO Silver's Avatar
HIO Silver
Read this tech article over at Fordication: How to Install Power Steering in a 2WD F100/250/350 - FORDification.com
ghanaguy
Dec 12, 2012 08:25 PM
okedokeno
28
Oct 26, 2012 10:45 PM
Jacks 65
Mar 17, 2012 04:30 PM
drof46
May 5, 2009 07:00 AM
HardFordCore
Feb 21, 2004 07:52 PM
