have been given a ford toploader 3 speed with id tag reading RAT-G2.Is this out of a truck and would it suffice behind my 390? Looks just like the one thats in it now. Also is there another name for this trans? Nobody understands a ford 3 speed. Is it a borg warner, tremac etc? I need to replace some seals in it but autozone specialist dont list a ford 3 speed. They keep calling it a t85. This may be a job for number dummy. Sic em boy.
My best guess is the power curve of the different engines. The 390 had about 50 more HP than the 360. All these trans have a final drive of 1.00 so I don't think you will have a problem running it behind your 390. If I am wrong...someone will chime in and set me straight.
yeah. it may even suit my 390 better with the lower gear ratio.idk. i just hope the bearings are beefier enough to hold up. im not thinking it will be a problem.
