Sponsored by: Real Truck
tbc problem
Old May 24, 2011 | 10:13 PM
danosll's Avatar
danosll
Trailering
tbc problem
Hi
I've been searching this site for somebody who may have had a similar problem. I changed my oem tbc because, although my old tbc was working perfectly it constantly showed tbc fault evrytime at start up which was annoying. so I changed it with a tbc from an identical truck( 06 f350 6.0l crew king ranch). the tbc fault doesn't come on at start anymore and the controller appears to be functioning properly(green light when connected,red when not connected) . the problem is even with the gain set to 10. the trailer brakes hardly work whether with the manual slide or with pedal pressure. when i pull out the breakaway switch the trailer brakes lock as they should . so i am asumeing the problem is the tbc . the question is can the tbc be adjusted or calibrated?
the trailer is the same 15 000 pound 5th wheel. I would pull with my old tbc which worked perfectly aside from the tbc fault. I mentioned before.
thanks in advance Dan
Old May 25, 2011 | 05:23 AM
senix's Avatar
senix
I would start by having someone step on the brakes. Go to the trailer wheels and listen to each drum independantly. Do you hear a buzz at each wheel?
If not then I suspect no power to that wheel. Check for broken wires.
If you check at the trailer plug I beleive each wheel will draw 3 amps if they are working. So 12 amps total.
Old May 25, 2011 | 06:44 AM
danosll's Avatar
danosll
Trailering
thank senix for the but the trailer wheels lock when I pull the pin on the braekaway switch and worked perfectly with old tbc ( aside from annoying TBC fault on the message center) but with new TBC brakes hardly apply with gain at 10.whether i activate manually or with pedal pressure. I thought there might be a calibration procedure or adjustment anybody might know of? thanks
Old May 25, 2011 | 07:22 AM
senix's Avatar
senix
You must start at the basics. I understand it worked with the old TBC but something may have happened.
For me in my investigation..that is where I would start.
Old May 25, 2011 | 07:33 AM
Help I M Stuck's Avatar
Help I M Stuck
It's the controller...mine did the same thing. I just replaced it with a Tekonsha P3 brake controller. http://www.etrailer.com/Brake-Contro...sha/90195.html This thing works way better then my factory one ever did. Comes with a pre-wired wiring harness for your truck..just plug it in. Now I just need to find out how to get the TBC Fault message to go away on the dash when i start the truck. It's alot better knowing I have the piece of mind to know my trailer breaks are going to work when I need them to work.
Old May 25, 2011 | 07:46 AM
danosll's Avatar
danosll
Trailering
thanks jeff
I checked out your link do you know if the p3 uses the same system with the brakes hydraulic pressure?
the sad part is, the reason I changed my original tbc is because of the annoying tbc fault message. other than that the unit worked beautifully( best I ever used).
first I'll see if I can find another oem tbc to try.
Dan
Old May 25, 2011 | 08:05 AM
Help I M Stuck
yes..the P3 works with electric or Hydraulic
Old May 25, 2011 | 04:20 PM
maverick22's Avatar
maverick22
How fast are you going when trying it w/ the new controller? Wasn't there a problem w/ the early ones not working unless you were going 15 or 20mph? I'm thinking that was fixed by 2006 though. Maybe something to try but w/ a trailer that big i'd want a long clear stretch in case that wasn't it.
I've got your original problem - thing works great just have the fault message. I hit the button to clear it every time, it's a pain but I'm cheap!
Old May 25, 2011 | 04:38 PM
danosll's Avatar
danosll
Trailering
even at 60 mph would sometimes give me 2 bars with my left pedal about to bend and the smell of asbestos coming in the vents.
you want to talk cheap the reason I don't have my old controller any more is because I switched it with a truck that was repoed by the bank and going to auction. I would love to have my fault message back.
Old Jun 17, 2011 | 10:24 AM
danosll's Avatar
danosll
Trailering
Hi everybody
finally got around to testing the controller with the trailer conected . when I push the manual slide . I am getting around 5 volts at the blue wire, both at the connector on the back of controller and at junction on trailer where 7 pin wire comes in. when I pull breakaway switch it is 12+volts. does any body know of a way to calibrate these. or of someone who rebuilds these?
Thanks guys
Dan
JoshC017
Nov 16, 2016 01:01 PM
blind180
Nov 14, 2016 10:34 PM
SolarKing
Apr 28, 2016 02:12 PM
BenKlink
Aug 17, 2015 08:48 AM
mnmwhit
Dec 16, 2012 01:56 PM
