Transmission Impossible (E4OD to ZF 5 Speed Swap)
Hey i am also looking for info on the same swap. I have a 93 donor truck, the exact same as my 95 psd. Redone1 said that you need the psd donor why? It would be sweet if my 93 would work cause it has everything i need. Sorry i dont have any input I too am looking for answers, Thanks, Chad.
I may also be stupid and wrong.
I think it's a different bolt pattern between the gas and diesel transmissions. Again, that's just from reading, and someone who knows more will hopefully confirm or deny this shortly.
The 6 requires either modifications to the trans tunnel and maybe firewall (the zf5 is a tight fit) or I believe a body lift.
The zf-6 and zf-5 have the same over-all ratio (1st to OD). The only two differences are 450 ft-lbs (rated) for the 5 and 600 to 650 for the 6. And, the zf-6 has a gear between the 1 and 2 of the zf-5.
As a result, most will tell you the swap to the 6-spd isn't worth it.
Ok sweet plgebbia, i am going to start the removal of the tranny soon then. I plan on tearing it down just to make sure everything is ok. Where could i get the PCM flashed? Also is it the box on the drivers side inner fender?
#30
I'm going to go ahead and bring this thread back to life.
Has anyone done a write-up on an automatic to manual transmission swap? If everything happens like it's supposed to, I'll be doing mine soon. I'm quite sure that I'm going to need tons of help, since I've never done anything like this before.
