Transmission Impossible (E4OD to ZF 5 Speed Swap)
#76
Good deal. Thanks for the fast replies. Nothing came loose, so no harm, no foul, I guess. I'll take it out whenever I can get help lined up, then. I tried to rep you both, but it didn't work.
Edit: By the way, is the starter bolts to the engine, right? If so, how important is it that I remove it? It seems like every transmission removal procedure I've read includes the removal of the starter.
#77
I've had my starter out one time, and it was a PITA due to my disabilities and it was the middle of December (in Idaho and outdoors; my truck doesn't fit in my garage). Anyway...
Take a look at it while you're under the truck. If you can R&R the tranny without removing the starter, I'd leave the starter alone. I have my tranny replaced by the dealer, so I'm not sure if the starter must come out first. With the PITA experience I had replacing my starter, if it doesn't have to come out, leave it where it is. You might disconnect the batteries, just to be safe.
#78
#81
Alright. Is there any way to get to the middle passenger bellhousing bolt without removing the downpipe. I can't even get a wrench on it. How in the world am I supposed to move that bolt with the downpipe nearly resting on it? I plan to do the 3" downpipe deal while the transmission is out, anyway, so it's not a problem to remove it. I was just wondering because I'd probably rather wait to take it out until the transmission jack isn't all in the way under there.
This leads me to my next question. Should I wait to put the 3" downpipe in until the new transmission is in to make sure I make room for the transmission? I'm not quite seeing how a 3" is supposed to fit under there, since the stock downpipe is nearly contacting my transmission.
I'm getting ready to remove the transmission now, so speedy responses are appreciated.
#82
Well i would suggest using a impact woble socket 1/2 drive. Hey I will try to follow your swap closely as i have the same thing planned. I forgot my password and havent been on in a while.. What did you do for a clutch, And how much did it cost that is my biggest concern? All i need to do is drag my donor back to my house and start tearing it apart...lol Good luck and i will try to give advice along the way!
#83
$700 for a solid mass flywheel and 350 hp clutch from Valair.
I can't even get a socket on that bolt without a wrench. There's simply no room. I just got back from Harbor freight to buy reciprocating saw blades to cut that downpipe up. I'm just going to remove it. I'll let you guys know how it goes.
#84
#85
I started to remove the downpipe. I've made two cuts so far, but I didn't do such a great job up top, so I've still got one cut left to go before it'll come out of there, but it's nearly there. For those planning to do a 3" downpipe, I can't stress enough how important good metal cutting blades are. I went into it with junk blades and it is a huge pain in the butt. I reckon that a better blade will make a big difference when I get on it tomorrow or the next day. I ran out of sunlight today, so I'm done for now.
#86
#87
#88
#90
Wouldn't the position of the downpipe be directly related to the engine/transmission? So, if the engine was more rearward, the dowpipe would also be more rearward. I think I'm misunderstanding what you're saying.
