excursion tank differances
Old May 23, 2011 | 08:15 PM
rat49f6's Avatar
rat49f6
im thinking about adding a excursion tank to my project truck,
when i look it up on car-part it shows diesel, gas from 4/9/01 and gas thru 4/9/01
my question is this:
what is the difference and will the gas ones work for a diesel??
Old May 23, 2011 | 08:27 PM
duck fan's Avatar
duck fan
Because racetruck
They are all the same. If you are going to use one from a gasser, clean it out first. Otherwise they are the same.
Old May 23, 2011 | 08:29 PM
rat49f6's Avatar
rat49f6
does the gasser one have a fuel pump in it like the super duty???
Old May 23, 2011 | 11:52 PM
Layson's Avatar
Layson
Any threads on the install of one of these. I picked up one a couple weeks ago
Old May 23, 2011 | 11:58 PM
rat49f6's Avatar
rat49f6
curious what u paid and gas or diesel tank?
Old May 24, 2011 | 12:03 AM
Layson's Avatar
Layson
It was 75 bucks without the cap and sending unit. But it does have the steel guard and mount for it...
Layson's Avatar
Layson
I don't know if it was gas or diesel... LOL
Old May 24, 2011 | 12:06 AM
rat49f6's Avatar
rat49f6
thats a dang good deal
Old May 24, 2011 | 12:10 AM
Layson's Avatar
Layson
It was from Joe aka CSIPSD...
Old May 24, 2011 | 06:06 AM
papadelogan's Avatar
papadelogan
Snowboard season cometh..
None of the Super Duty's or Excursions had the fuel pump in the tank from the factory. Fuel level sending unit, "mixing chamber", etc. sure, but not the pump. All of them have it mounted on the frame rail.
Old May 24, 2011 | 07:03 AM
comadvan's Avatar
comadvan
Would the sending unit work correctly? I have a 8' bed which I thing has a 38 gallon tank.. how much bigger is the Excursion tank?
Old May 24, 2011 | 07:35 AM
locknload223's Avatar
locknload223
The Excursion tank is 44 gallons.
Old May 24, 2011 | 09:22 AM
UP_There's Avatar
UP_There
I wonder if that would even fit on a Crew Cab shortbed?
Old May 24, 2011 | 10:11 AM
F250_'s Avatar
F250_
IIRC, it will fit behind the axle where the spare tire goes. I'll try to take some measurements tonight and compare the space on my Ex with that on my short bed F250 (if I can remember). I believe it was Ziggy (Cory) who did this conversion on his truck, and I'm sure that he would be happy to answer any questions you have. I'm considering the same thing myself, but can't decide if I want to give up the bed space for my spare which still fits underneath. This wasn't an issue at all for Cory due to the size of his tires.
Old May 24, 2011 | 11:18 AM
rat49f6's Avatar
rat49f6
Cory does have it under his short bed.
I thought the gas super duty pickups have the fuel pump as party of the sending unit
Didn't someone use the gasser pump and sending unit to feed there stock pump?
