excursion tank differances
im thinking about adding a excursion tank to my project truck,
when i look it up on car-part it shows diesel, gas from 4/9/01 and gas thru 4/9/01 my question is this: what is the difference and will the gas ones work for a diesel?? |
They are all the same. If you are going to use one from a gasser, clean it out first. Otherwise they are the same.
does the gasser one have a fuel pump in it like the super duty???
Any threads on the install of one of these. I picked up one a couple weeks ago :D
curious what u paid and gas or diesel tank?
It was 75 bucks without the cap and sending unit. But it does have the steel guard and mount for it...
I don't know if it was gas or diesel... LOL
thats a dang good deal
It was from Joe aka CSIPSD... :D
Originally Posted by rat49f6
(Post 10378205)
Would the sending unit work correctly? I have a 8' bed which I thing has a 38 gallon tank.. how much bigger is the Excursion tank?
Originally Posted by comadvan
(Post 10379516)
Originally Posted by locknload223
(Post 10379627)
The Excursion tank is 44 gallons.
IIRC, it will fit behind the axle where the spare tire goes. I'll try to take some measurements tonight and compare the space on my Ex with that on my short bed F250 (if I can remember). I believe it was Ziggy (Cory) who did this conversion on his truck, and I'm sure that he would be happy to answer any questions you have. I'm considering the same thing myself, but can't decide if I want to give up the bed space for my spare which still fits underneath. This wasn't an issue at all for Cory due to the size of his tires.
Cory does have it under his short bed.
I thought the gas super duty pickups have the fuel pump as party of the sending unit Didn't someone use the gasser pump and sending unit to feed there stock pump? |
