EBPV Brake Barely Functioning
Old May 23, 2011 | 04:24 PM
h2guy's Avatar
h2guy
Lately, the EBPV brake function just does'nt work as hard as it used to when I turn it on.
Before, I could hear the unit doing its thing and now you really have to concentrate to hear the difference when I turn it on.
And of course, there is only very little braking action when its on.
Can the valve itself get gummed up and not close properly??
Can it be that the EPS tube is clogged?? If so, does this prevent the gate from closing completely??
Using a lot more foot braking action than has been usual these past 10 yrs. Up here in northern NV currently and with 15k behind you, an exhaust brake is really needed.
Old May 24, 2011 | 03:20 PM
h2guy's Avatar
h2guy
Jeez, I would have thought one of you people understood this component and its functioning.
Old May 24, 2011 | 03:35 PM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
How are you making the EBPV function? If you have a switch to function it, have someone function it while you look to see if the valve is closing right.
Old May 24, 2011 | 03:39 PM
Shake-N-Bake's Avatar
Shake-N-Bake
Do you have an auto or manual trans?
Have you checked it visually to see if it's operating? The lever points to the driver's side when off (open) and towards the passenger side when on (closed).
Does the lever move when you throw the switch?
The tube and sensor have no effect on the manual over ride switch used to control the EBPV.
Old May 26, 2011 | 02:59 PM
h2guy's Avatar
h2guy
Hey Greg, thanks for the comeback.
Its been cold & rainy here so have'nt been able to get out and check on the valves operation. But will do it first opportunity. Hopefully, it just needs freeing up or something.
WiFi here is really spotty so excuse the slow response.
Again, thank you.
xbox73
May 5, 2014 06:47 PM
mtnsammy
Feb 26, 2014 11:17 AM
RMPC
16
Jul 8, 2009 12:23 AM
FARM69
Jun 7, 2007 01:20 PM
bigtorque
Dec 26, 2006 02:16 AM
