High speed vibration
Old May 23, 2011 | 01:59 PM
Jeepers2003's Avatar
Jeepers2003
Looking for ideas as to what would cause vibration at high speed (65-70 MPH). The vibration seems to be coming from the drivetrain and not suspension. I'm thinking unbalanced drive shaft maybe?
I notice no vibration at all at speeds up to about 60 or so, but on the overtake, they start up and are quite nasty.
Old May 23, 2011 | 02:39 PM
montana_highboy's Avatar
montana_highboy
Often times an out of balance tire won't cause any issues until you reach highway speeds, just a thought.
Old May 23, 2011 | 02:42 PM
devino246's Avatar
devino246
I agree^
Do you feel the shaking in the steering wheel? If not, rotating the tires and taking her for a drive could help diagnose.
Old May 23, 2011 | 02:50 PM
Sleepy445FE's Avatar
Sleepy445FE
As montana said an out of balance tire often won't show itself until you get up to speed. I had this problem a while back. It was fine until I got up to about 50mph, then start the paint shaker. Also check that the d-shaft is in phase.
Old May 23, 2011 | 03:35 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Yes on all the above possible tire issues, ck the d/s u joint condition and put a level on it to ck straightness (a metal level like you use in construction work).
Also look for a spot where a d/s balance weight might have came off. They are tack welded on there so look for a spot like that?
Have you removed the d/s lately and got it outta phase when reinstalled? Also after you ck the tires for broke belts/bulges, rotate their position front to rear, and see if its still there.
If its a 4x4 remove the rear d/s all together (top slip yoke included) and lock in the hubs and give it a test drive. Ck you rear end fluid level.....
All I know in 30 seconds.
Old May 23, 2011 | 04:26 PM
Jeepers2003
Thanks guys. The rear shaft came off violently one day when a U joint grenaded on me one day. had to cross 3 lanes of traffic to retrieve it
That's why I thought an out of phase shaft might be the issue. I'll check the tires though and see. Guy wants 80 bucks to check the balance.
Old May 23, 2011 | 04:46 PM
77&79F250's Avatar
77&79F250
phase ck
I think after that thing came out from under the truck and skidded across 3 lanes of traffic ( I remember your story) I would of went and got a JY replacement.
Out of phase is a easy ck, are the ears (part where the u joint cap goes) on each part of the d/s in line with each other? If not so just slide apart and slide back together after skipping a few splines.
Use a long metal level to ck it then, from end cap to end cap of u-joint. $80 bucks, damn that hurt.
Old May 23, 2011 | 04:50 PM
devino246's Avatar
devino246
$20 a tire??? It takes less than 30 minutes to do all four.
Old May 23, 2011 | 04:55 PM
Jeepers2003
To clarify, I meant 80 bucks to check the balance on the shaft.
Tire balance is covered by the tire seller. I don't really think its a tire issue though. The vibes really seem to be coming from the engine/transmission or shafts and gears.
Gonna take some of the suggestions and check the straightness on the shaft.
Old May 23, 2011 | 10:51 PM
77&79F250's Avatar
77&79F250
The level is a on the truck way or pull it and do the ol roll is across the shop floor trick.
Good luck.
Old May 25, 2011 | 09:15 AM
Vaokie1's Avatar
Vaokie1
Same thing happens to mine but...
I have been afraid to ask anyone because the smarta** in me can hear some of the replies (quit driving it that fast and it won't vibrate) I also get a screeching noise (not metal on metal grinding but like a wire laying across the d/s scraping) that comes and goes from the drive train area when I accelerate. I jacked it up and spun the back tires but could not duplicate the noise. The funny thing is sometimes the noise is extremely loud and other times I have to strain to hear it! Also is there a standard location for the d/s weight?
Old May 25, 2011 | 03:02 PM
77&79F250's Avatar
77&79F250
V.... I would ck your rear brake drums setup for a broken e brake cable or other internal issue? If its a chatter its a dry u-joint, no clue on the screech except a slipping alt/fan belt?
Or maybe a rear end pinion bearing? Or rear wheel bearing? Yea NOT what you wanted to hear as a suggestion, sorry.
Old May 26, 2011 | 08:33 AM
Vaokie1's Avatar
Vaokie1
Noise
I thought it might be a cable also but I could not duplicate the noise when I had it jacked up and spun the rear wheels by hand. Unfortunately I now have a vibration at low speed that makes me think my u-joints are going out.
CbrMike
1997 - 2003 F150
Apr 20, 2016 12:49 PM
lebanontn
Aug 17, 2013 12:53 PM
Gomer1
May 23, 2011 02:40 PM
kdawg249
Jan 27, 2011 08:41 AM
nebmike
Jun 10, 2008 12:07 PM
