*9 ford Ranger revving like crazy.
Old Mar 24, 2003 | 01:55 PM
HLP's Avatar
HLP
Hi everyone,
I have an 89 Ford Ranger with about 300 k and auto transmission. The truck keeps revving high. Can be any day, any time the revs will suddenly spike up and stay there until I either switch it off or hit the throttle pedal a number of times. Even happens when driving, dangerous. Checked the throttle cable seems okay no springs or cable sticking. I'm stumped can you help. Thanks
Old Mar 25, 2003 | 11:33 AM
amp17757's Avatar
amp17757
My first suspicion would be the TPS (throttle position sensor) malfunctioning. One fairly easy way to confirm this would be to get the engine idling normally, then, while still idling, pull the plug off the servo motor that electronically controls the throttle via commands from the TPS. With the servo disconnected, it will never receive the signal to change the idle speed. THEN, if you still have the problem while driving over the next few days, it surely isn't the TPS. But, if the problem has suddenly disappeared, it could very well be the TPS. The good news it that it might simply need cleaned (including all connections). Don't spend any money until you clean & check everything.
Old Mar 25, 2003 | 02:35 PM
HLP's Avatar
HLP
Smile *9 ford Ranger revving like crazy.
Will check this out right away. Cheers.
Harabec
19
Feb 17, 2021 10:43 AM
towmaster
Mar 14, 2011 09:40 AM
mr_ranger-79
Jan 17, 2011 09:36 PM
phix
General Automotive Discussion
Jun 8, 2010 09:25 AM
Boss50
Mar 25, 2008 08:33 AM
