Gas Gauge Blues
Old May 23, 2011 | 01:45 PM
devino246's Avatar
devino246
Gas Gauge Blues
The gas gauge in my '79 F150 Custom has been... strange. When I first got it, it read empty. Added some gas, still empty. Went to start it up one day, reads half. Last Monday it started reading past full. The needles been staying a good 1/4th inch past full for the last week and I should be down a quarter of a tank. It seems like it might be a short somewhere. Any ideas? Thanks
Old May 23, 2011 | 02:17 PM
Death85e's Avatar
Death85e
Sounds like a short in the wiring......not sure exactly but i am sure someone with alot more knowledge will chime in soon.
Old May 23, 2011 | 02:27 PM
devino246's Avatar
devino246
One of the POs spliced into a few wires for who knows what. One of these was orange, which is for the fuel gauge according to my Haynes Manual, but it has a white stripe in it.
Old May 23, 2011 | 04:37 PM
jsutton's Avatar
jsutton
Ground the wire going to the sending unit and gauge should peg full, if it does you know the problem is in the tank and not the wires between the tank and gauge. I've had to replace the float in the tank because of holes twice, that'd be something to check for too. Fuel will get inside the float and make it read wrong because of the level or sit on the bottom showing an empty tank all the time.
Old May 23, 2011 | 04:43 PM
devino246's Avatar
devino246
Its already pegged full. Turn the key and it goes right to it. Could it be the sender going bad?
Old May 23, 2011 | 04:47 PM
jsutton's Avatar
jsutton
It's possible I guess. Maybe there's an exposed part of wire somewhere and it's grounding out causing the gauge to peg full?
Old May 23, 2011 | 04:48 PM
devino246's Avatar
devino246
Thats what Im thinking...
Old May 23, 2011 | 05:37 PM
devino246's Avatar
devino246
3 wires that were molested. The gauge shows more gas when theres more current, correct?
Old Brown Truck
Oct 7, 2014 08:17 PM
The other Joe
Jun 9, 2014 11:38 AM
afonda
Feb 16, 2014 10:12 PM
xmontex4
19
Dec 27, 2013 02:50 PM
bigin302
Dec 3, 2003 09:16 PM
