Sponsored by: Auxito
1998 lifter spacing specs
Old May 23, 2011 | 11:01 AM
Wendell Lind's Avatar
Wendell Lind
Ihave a lifter tapping and am going to replace the lifter and push rodsand need to know the proper spacing for the lifter. Thanks for any help
Old May 23, 2011 | 07:51 PM
Bluegrass 7's Avatar
Bluegrass 7
You need to tell us what motor you have.
A v6 has push rods, a v8 does not.
V8s are overhead cam and have no push rods, only direct acting lifter assemblies.
Since both are hydraulic they do not work with any clearence.
The clearence is all taken up inside the lifter.
So a valve train noise due to a lifter is either a faulty lifter, worn camshaft lobe or push rod tip or some other associated wear depending on which engine.
Good luck.
airharley
Aug 31, 2006 10:46 PM
Randyb12
Apr 9, 2004 12:01 AM
markallen
Jun 30, 2003 10:23 PM
BB
13
Nov 22, 2002 06:22 PM
turbojeff
Mar 28, 2002 10:42 PM
