Truck will not stop beeping
Old May 23, 2011 | 11:00 AM
Barshoe's Avatar
Barshoe
I installed a new brake controller and replaced the fuse but know the in cab beeper keeps going off I did notice today that the cruise control is not working the fuse is not blown any suggestions
Old May 23, 2011 | 02:10 PM
esaycho's Avatar
esaycho
when you turn the key on, does the airbag light come on, if not then your airbag light has burnt out and that's the reason for the beeping. Second thing is does the horn work?
Old May 23, 2011 | 03:00 PM
timmyboy76's Avatar
timmyboy76
what he said....easy fix, if you get the "right" 12v light buld, or led. Another possibility is, had it just rained? If so, your windows' leaking, causing water to hit the GEM module...unless you have an 02-03, then they went to different module, but dont quote me on the year though
Old May 25, 2011 | 07:01 PM
Barshoe's Avatar
Barshoe
It was my own fault the parking brake was pushed on when I was on the floor. Thanks for the help
John R T
6.7L Power Stroke Diesel
Apr 25, 2017 12:21 PM
draboo
Dec 14, 2015 11:04 PM
mntncat
May 17, 2012 02:44 PM
Jaaaaaaackman
Sep 21, 2007 09:33 PM
nmlaz
Mar 5, 2007 09:18 AM
