STARTER PROBLEMS
Old May 24, 2011 | 10:39 PM
Rogue_Wulff's Avatar
Rogue_Wulff
Originally Posted by RAY1986F150
Okay, I did manage to get the truck started tonight. However I had to dodge all the tornados and didn't have time to work on that safety switch. Truck sounds good with open headers!!
Them dern 'naders were all around us weren't they?
BTW, I'm in Sapulpa.....
Old May 24, 2011 | 10:46 PM
RAY1986F150's Avatar
RAY1986F150
Video of start up using the above mentioned screw driver jumper procedure.
Old May 25, 2011 | 07:12 AM
RAY1986F150
Right down the road from me. I am right north of Owasso in Collinsville.
Old May 25, 2011 | 09:05 AM
Alcaeus's Avatar
Alcaeus
Replace the ignition switch. If it doesnt fix it you can return it. Otherwise I'd check the wiring to the switch.
Something might have been pulled apart during transplant.
Old May 25, 2011 | 09:12 PM
RAY1986F150
Okay ya'll, I finagled with the neutral switch and didn't get anything. I went to the parts store and got an ignition switch. That didn't work. So I went on to test the starter solenoid. I took the red wire off the solenoid and ran a meter over it to see if I was getting 12 volts when the key was turned to "start". I was getting 12 volts. Therefore my problem must be the solenoid. I plan on getting one at the parts store tomorrow evening. I will let ya'll folks know how it goes.
Old May 27, 2011 | 07:14 AM
RAY1986F150
Okay ya'll. I replaced the starter solenoid and she fired right up. Now I just need some exhaust. Open headers are loud. My flowtech afterburners should be in today.
