steering box
Old May 22, 2011 | 09:18 PM
zakk's Avatar
zakk
steering box
so i busted the steering box mudding in my truck a few weeks ago. is there any thread on how to get it off my tuck is pretty dirty right now so i cant see where all the bolts are and everything so i just figured id ask if there are something i should know before i try tomorrow.
Old May 22, 2011 | 10:19 PM
farmert's Avatar
farmert
It is pretty straight forward, you will have to remove the 2 hoses for the power steering, one bolt that holds the rag joint onto the steering sector, one tie rod to the pitman arm, and finally the three bolts that hold the box to the frame. I find that is the easiest to remove the tire and work threw the tire well.
Old May 22, 2011 | 10:24 PM
zakk's Avatar
zakk
sounds simple thank you!
Old May 22, 2011 | 11:35 PM
Country_boy_2007's Avatar
Country_boy_2007
ill let you know, im gunna be doing it tomorrow
Old May 22, 2011 | 11:46 PM
zakk's Avatar
zakk
sweet man take pics if ya can
Old May 22, 2011 | 11:52 PM
Country_boy_2007
can do, anything specific you want to see?
Old May 23, 2011 | 12:21 AM
zakk's Avatar
zakk
nothin really to specific maybe just some random pictures of things for future lookers that search it up cause i did and couldnt find anything if i do mine tomorrow ill try and get some also
Old May 23, 2011 | 12:24 AM
Country_boy_2007
i can do that
Old May 23, 2011 | 12:47 AM
91dirtydiesel's Avatar
91dirtydiesel
I did the same thing with mine, took it wheeling once and steering went bad. Learned my lesson, never done it since. (Hardcore wheeling) I still go in mud and stuff when needed just now I don't pretend im a jeep or yota and not go through rough deep trails haha save that for them
Old May 23, 2011 | 12:56 AM
zakk's Avatar
zakk
haha yeah the fun was worth the breakage for me, i would do it again ill just let my buddies test how the deep the hole is in their trucks before i try it in mine this time
Old May 23, 2011 | 10:23 AM
Country_boy_2007
if your gunna do that with a big heavy truck like these, hydro assist is the only way to go
Old May 23, 2011 | 10:45 AM
zakk's Avatar
zakk
sooo how do i get the tie rod off?
Old May 23, 2011 | 10:52 AM
snaponprofile's Avatar
snaponprofile
Tie rod puller or a hammer if you are good with one. Just talking from experience, don't try to take the pitman arm off with the box on the truck. It will be much easier with it on the work bench.
Old May 23, 2011 | 11:09 AM
farmert's Avatar
farmert
If you don't have a pickle fork, hit the end of the pitman arm, as if you were trying to drive the arm towards the rear of the truck. 3 or 4 blows with a 2lb. hammer should do it. The shock of hitting the pitman arm will loosen the tapered tie rod end.
Old May 23, 2011 | 11:36 AM
91dirtydiesel
Also try turning castle nut upside down and screw it on then give that some hits with hammer so u don't gum up any threads
