Axel studs?
Old May 23, 2011 | 04:57 PM
finneys98xj's Avatar
finneys98xj
Originally Posted by tbear853
OH .... .... OK .... thought you were speaking about wheel studs, then it sounded like you meant the 8 or so studs that secure the drive axle in the floating hub of your 3/4 tone axle, and now ..... I'm believing that you mean the 4 bolts that bolt the brake backing plate to the end of the axle housing?
They are usually funny looking heads on them, kind of squished looking long oval heads. Often called "T-bolts", maybe 3/8" or even 7/16" diameter? That picture is a 9" Ford rear in a F100/150. Your's is maybe a Dana 60 with floating hubs.
Do you have one to gage thread diameter, etc?
Ford Racing M-4002-B - Ford Racing Brake Backing Plate T-Bolt and Nut Kits - Overview - SummitRacing.com
Those above are 3/8-24 NFT 1.30" long Ford bolts for the 9" rear sold by Ford Racing M-4002-B available Summitt, etc. They may not work for your Dana? '
You are right, not as easy to find. Not enough room for a bolt's head.
That is EXACTLY what I am looking for!! It is for a ford 9in that is in my 78 f150 4x4. I haven't added that to my sig yet but I'm about to.
Old May 23, 2011 | 05:05 PM
tbear853's Avatar
tbear853
Yeah .... I saw that after I posted ..... when I looked back through the thread. I had missed that. I was editing my response as you were posting a reply to my unedited reply .... LOL.
They weren't cheap! Might be some cheaper standard ones available .... but the likely are stout.
Old May 23, 2011 | 05:46 PM
finneys98xj
what is stock size? 3/8's or 1/2's
Old May 23, 2011 | 06:25 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
I assumed after I read post #9 that the T bolts are what you wanted, but didn't wanna chime in till you confirmed.
1962/78 F100, 1975/78 F150 and possibly 1979 F100/150 (and etc) as original:
C2AZ-2248-A .. T Bolt-Axle Housing to Backing Plate / 1/2" -20 x 1 13/16" long / Available from Ford.
1973/79 Ford Light Truck Parts Catalog sez in the rear axle parts lists for the 9" rear axle:
To obtain the correct parts for 1979, you must measure the backing plate bolts to see if they are 1/2" or 3/8."
1978/80 Passenger Cars / 1979 F100/150 (and etc):
387997-S (replaced D8AZ-2248-A) .. T Bolt-Axle Housing to Backing Plate / 3/8" -20 x 1 23/64" long / Obsolete
1979: If not this puppy, they're C2AZ-2248-A's.
Old May 23, 2011 | 06:39 PM
finneys98xj
Thanx numbers.
Old May 23, 2011 | 07:33 PM
finneys98xj
I found a set of 8 online for 15 plus shipping. But they are only and inch long. I dont think they would be long enough would they?
Old May 23, 2011 | 08:38 PM
finneys98xj
I can I use a 3/8 set in place of the 1/2?
Old May 23, 2011 | 08:54 PM
tbear853's Avatar
tbear853
I'ld use what fits the holes.
Using 3/8" bolts in 1/2" holes will allow the backing plate to rotate some forward at first brake application until next time you back up and hit the brakes, when they may allow it to rotate backwards when brakes are applied ... and so on. This movement will not help the brake lines that have to flex to go with the plate and the bolts will soon be loose .... at best.
Old May 23, 2011 | 08:59 PM
finneys98xj
The only set of 1/2 inch studs I've found are only 1.00 long. I don't think they would work. The OEM parts are 3.77 a piece but I don't know if they come with the nuts or not.
Numbers does your parts books show a seperate part number for the nuts or do you know?
Old May 23, 2011 | 09:56 PM
NumberDummy
Not.
Numbers does your parts books show a separate part number for the nuts or do you know?
Do I know? Do birds fly and ducks swim? Do bears **** in the woods? Is Obama the prez?
C2AZ-2248-A .. T-Bolt-Axle Housing to Backing Plate 1/2" -20 x 1 13/16" long / Available from Ford (come in a package of 4).
MSRP each: $5.33 // FTE sponsor PARTSGUYED.COM price each: $3.84.
34424-S7 .. Lock Nut-1/4" -20 / Obsolete
You can purchase lock nuts in any parts store.
Old May 23, 2011 | 10:13 PM
finneys98xj
Sweet I didn't know if it took special nuts if plain nut would do thanks numbers. If I want on my phone I would add Rep.
To answer the question bear do **** in the woods! Lmfao
ramick
16
Jul 22, 2014 10:05 AM
tykateexcursion
Apr 1, 2008 08:08 PM
rangerguy52
Bronco II
Jan 7, 2005 10:35 PM
mpidge1
Bronco II
Dec 28, 2003 10:23 PM
steve83
1978 - 1996 Big Bronco
Jan 10, 2003 05:57 PM
