Help on a F750 needed
Old May 22, 2011 | 04:02 PM
JimG1098's Avatar
JimG1098
Hi gang.
Still looking for some help on the F-750/, 54'
I am in need of a vac advance for a 279, Standard part # VC-15, or Echlin VC-920, Warner V181. Dont know the ford # because my paerts CD got destroyed.
#2 I do not have a picture of where my coil goes. Any ideas???
#3 I am close to pulling the cab. everything is disconected. Because there is a pump body welded to the chasis, I can only go streight up with the cab. Do I have to pull the pitman arm and stering box.
Also the clutch pedel?
Thanks for any hepl
JimG1098
Old May 22, 2011 | 06:59 PM
Harrier's Avatar
Harrier
Do these images help any?
Old May 23, 2011 | 06:00 AM
JimG1098's Avatar
JimG1098
Joe,
thanks for the pics. On your drawing, where the coil is, on mine, i have a secondary governor under the carb for the fire pump. There appears to be no mounting holes on the intake manifold that match the coil bracket.
You have quite a project there.
Thanks for the asist
Jim G 1098
