Sticky Brake Caliper Pistons
Old May 22, 2011 | 03:09 PM
robinsonpowerstroke's Avatar
robinsonpowerstroke
I've just noticed my truck pulling to the left very slightly while going down the road. I jacked up the front end and the drivers side tire spins a little harder than the passengers which free spins. Pulled off the caliper and the hub spins free. Thought maybe the slide pins so I pulled them out and the were free of rust and still good antiseize. Must be that the caliper pistons are starting to get gummed up. Anyone know of a way to free up the pistons or just buy a replacement caliper?
Old May 22, 2011 | 04:33 PM
joeyd61's Avatar
joeyd61
my left front did the same and for 50 bucks just replace......
Old May 22, 2011 | 05:32 PM
robinsonpowerstroke
Think I'm just going to do the same.
Old May 22, 2011 | 07:10 PM
dagren99's Avatar
dagren99
Before you ditch your caliper - check the brake hose on that side. if it looks iffy replace it & bleed the system. Drive it and see if the problem persists. I dumped a perfectly good pr of calipers only to find the hose was collapsing on the pass side of our 03
Old May 22, 2011 | 07:13 PM
robinsonpowerstroke
Originally Posted by dagren99
Before you ditch your caliper - check the brake hose on that side. if it looks iffy replace it & bleed the system. Drive it and see if the problem persists. I dumped a perfectly good <ACRONYM title="Page Ranking">pr</ACRONYM> of calipers only to find the hose was collapsing on the pass side of our 03
How could I tell if the hose was collaped inside? Will it have a spongie spot in it?
Old May 22, 2011 | 07:40 PM
dagren99's Avatar
dagren99
Yup - it'll feel squishy and may have a bulge in it. Mine also had a bunch of cracks in it but wasn't leaking yet.
Old May 22, 2011 | 09:14 PM
robinsonpowerstroke
Ok I'll check it out first. Thanks for the heads up.
AbandonedBronco
1978 - 1996 Big Bronco
Jan 10, 2015 05:51 PM
Big-Red-Lariat
2009 - 2014 F150
Mar 19, 2014 01:26 PM
waterbear
Aerostar
Aug 24, 2013 03:10 PM
DreadyDiggs
1997 - 2003 F150
Apr 11, 2010 05:27 PM
Neil64
Apr 6, 2010 10:19 AM
