1978 - 1996 Big Bronco
Stuck in Low 4WD
Old Mar 24, 2003 | 11:43 AM
RMbros's Avatar
RMbros
Stuck in Low 4WD
After an accident last week (see my Best <a href="http://motorhaven.autoanything.com/">bumper</a> Buys post) I thought I only had superficial damage. Now I'm wondering if something worse may have happend. I somehow got into Low 4WD, something I haven't ever been able to do before, and I can't get out.
Neither of the 4WD lights is on (the Low 4WD didn't come on, but it was obvious I was in it), but I am obviously in 4WD and can't get up over 20mph.
So, a couple of questions:
1. What's the problem?
2. How do I fix it?
3. Could it be related to the accident?
A little more info - '94 EB Bronco, automatic, push button 4WD (I know, not ideal, but I bought the truck used).
The accident pushed the <a href="http://motorhaven.autoanything.com/">bumper</a> back into the driver's side tire hard enough to mess up the steering wheel alignment. The truck still goes in a straight line, but the steering wheel is rotated about 30 deg. from where it used to be.
All input is appreciated.
Old Mar 24, 2003 | 09:38 PM
saanders's Avatar
saanders
Stuck in Low 4WD
Is it an electric/push-button or mechanical shift transfer case?
Old Mar 24, 2003 | 09:40 PM
saanders's Avatar
saanders
Stuck in Low 4WD
Never mind -- I just saw it's push-button in your original post.
Old Mar 25, 2003 | 02:23 AM
dassmoof's Avatar
dassmoof
Stuck in Low 4WD
Did you put the truck in neutral and then try and get out?
Old Mar 25, 2003 | 10:26 AM
RMbros's Avatar
RMbros
Stuck in Low 4WD
I tried putting it in neutral, rocking, revving in neutral, and shifting on the fly. Nothing worked.
I finally gave up and took it in for repairs. As I was pointing out the other damage, I noticed that the auto-locking hub on the driver's side was cracked. I guessed I missed it because of all the sludge and snow. Hopefully, this is the fix.
Thanks folks!
notforyou
Jun 26, 2003 03:44 PM
Chas1234
Mar 27, 2003 01:49 PM
chado
Mar 27, 2003 12:05 PM
DILENGE
Mar 26, 2003 10:35 AM
teamwizard
Electrical Systems/Wiring
Mar 25, 2003 07:51 PM
