gvwr vs towing capability
Old May 22, 2011 | 12:09 PM
emd160's Avatar
emd160
when i go to ford direct and build a truck where you pick bed length and cab style it says towing capability 12,500 whats the differnace between that and gvwr?
Old May 22, 2011 | 12:39 PM
Tom's Avatar
Tom
GVWR = Gross Vehicle Weight Rating. This is exclusive to the tow vehicle and has little bearing on how much the truck can tow. Meaning on you two axles your truck can weigh 12,500 lbs regardless of how much is behind it.
The towing weight rating is completely separate.
Old May 22, 2011 | 01:02 PM
emd160's Avatar
emd160
So is gcwr the same as the tow rating? And for a f 350 reg cab 6.7 with 18 wheels would it be 23.5k as I seen in the order guide?
Old May 22, 2011 | 01:21 PM
Tom's Avatar
Tom
Not quite.
GCWR is the maximum weight for your truck and trailer combination. Figure that F350 would weigh somewhere around 8,000 lbs would leave you with a 15,500 lb towing rating.
The truck and trailer along with everything in it can never exceed 23,500 lbs.
Old May 22, 2011 | 01:22 PM
emd160's Avatar
emd160
Thanks crazy001 appreciate the info
blue924.9
Feb 26, 2013 05:02 PM
sasquatch999
Jan 5, 2008 03:27 PM
waypoint
6.4L Power Stroke Diesel
13
Jul 23, 2007 11:58 PM
audiophil99
Oct 20, 2003 11:15 AM
gilatrader
All Things Towing
Jun 4, 2002 02:15 PM
