Quick A/C question
Old May 22, 2011 | 08:55 AM
kaduh's Avatar
kaduh
Quick A/C question
I fianlly decided to replace the dreaded white vacuum line in the engine compartment a couple of weeks ago. There was literally nothing left of it! Everything worked except Max AC on the high fan setting prior to fixing it. Now, the only blower setting that works is when it's set on high??? Is the fan selector **** run off of vacuum? I thought it was ony the temp settings that rely on vacuum and the fan setting was electronic. I searched here but couldn't really find my answer. I also googled the schematic, and it doesn't show the fan select switch on what I found.
Just curious for now since I'm in Houston and having the A/C on Max-high is definately not a problem. Any help is appreciated in advance.
Old May 22, 2011 | 09:25 AM
L. Ward's Avatar
L. Ward
Check the rheostat for the blower motor. It's either bad, or you managed to unplug it. It looks like this and is mounted on the heater box under the hood
Old May 22, 2011 | 11:32 AM
Volvo92906's Avatar
Volvo92906
Those arent the blower motor, they are the resistors for the blower motor. And yes, as L. Ward mentioned check those because if they are bad you will only have the "high" setting because that is from direct battery power.
SilentlySoaring
Oct 6, 2020 09:47 PM
AF_MAC
Aug 27, 2014 08:51 PM
bass-n-fire
21
Jul 27, 2011 06:06 PM
smashclash
22
Jul 20, 2010 01:56 PM
ecsmith0624
Sep 6, 2007 10:22 AM
