engine braking
Old Mar 24, 2003 | 10:50 AM
shunshine X's Avatar
shunshine X
engine braking
I seem to have a problem (I think) with my transmission.
It is a "01 X PSD with appr. 73k mls on it.
The transmission is shifting fine but when I would like to downshift manually(trying to engine brake) the transmission does shift's down (RPM's go up) but as soon as I let go of the accel. (wich i want when going downhill) the transmission drops to idle.
Not neutral because when i want to accelerate again it is still in gear. The trans. does not drop to idle rpm's when overdrive is on.
It used to shift down but it is not doing it anymore.
My dealer could not find any problems and did not understand what I was talking about.
Does this problem sound familiar to anyone out there.
Thanks for any info!
Sunshine X
Old Mar 24, 2003 | 02:56 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
engine braking
Your coast clutch is not working.
There are several reasons it may not work, but by far the most common is the snap ring that holds the clutch together comes unseated and the clutch falls apart. It's held in place by other parts, but it won't function like this.
See if the dealer will run the diagnostics in the <a href="http://motorhaven.autoanything.com/">shop manual</a> for the coast clutch. If they do, they'll be removing the transmission to repair it.
Old Mar 24, 2003 | 03:03 PM
shunshine X
engine braking
Thanks mark
It sounds expensive to have it fixed
Could it do any more harm if I don't fix it soon?? (everything is running fine, the auto trans. shifts smooth)
Old Mar 24, 2003 | 08:30 PM
Mark Kovalsky
engine braking
It might, or it might not. Sometimes when this happens bad things happen to the rest of the transmission. Sometimes they can run like this for a long time.
It isn't a difficult repair once the transmission is out. It can't be done with the transmission in the truck.
LiquidSpecialties
2004 - 2008 F150
Dec 21, 2014 06:54 AM
kingpincozz
Aug 24, 2012 06:46 AM
MarkNtennessee
Sep 16, 2010 08:58 AM
nubwon
Mar 31, 2007 08:50 PM
