emission code plus foul smell
Did a search and didn't come up with much. Emission code has come on today an then off again (twice). Bad smell upon stop to fill up (smells like burned rubber), thought it was from somewhere else, but think it's the truck. Any and all ideas appreciated!!!
But to answer your question, the "code" I got was just the little orange picture in the lower left dash that looks like a transmission (I originally thought it was a transmission code until I looke it up). The manual states that it is an "Emission system" code.
. Lower left corner of your cluster, just below the low fuel light and just above the fasten seatbelt indicator? If so, then that is the light that illuminates when your PCM (Powertrain Contril Module) detects a fault. If your cat is clogged, then that light might come on. Best thing to do right now is get your codes read and see what comes up. If you live somewhere that does not require emission testing then just remove it and install a straight pipe in it's place. If you have emissions testing, then remove it (if you can) and gut the insides and then re install so it appears normal during visual inspection. If you post your location, there may be someone near you who can read your codes for you.
