Needs help with 4 WD
heres the problem, Iput it up on a lift and checked the Motor on thr transfer case, removed it and turned the the tyransfer case manually. The front drive shaft from the trans to the front whee in gear manualy. The front wheels do
n't turn. I'm going to put on Warn locking hubs. The other problem is, the passenger side front axle won't turn when engaged.
