Sponsored by: Real Truck
2005 Ford Hublock Failure Question
Old May 20, 2011 | 04:04 PM
guzzlin_gas's Avatar
guzzlin_gas
I have an 05' F-250. I had a hublock that was not disengaging so I disassembled it & found that the needle bearings in it had seized. It looks like I can get a new bearing for $13 online instead of the $200 that Ford wants for a new hub. My question is can I put the locking cap part of the hublock back on the hub & drive the truck until the bearing arrives. Obviously I wouldn't be able to use the 4 wheel drive, but it doesn't look like it would tear anything up since it would act like a hub that wasn't locked in.
Old May 20, 2011 | 04:15 PM
CPaulsen's Avatar
CPaulsen
Yes you can....you don't even have to put the outer part of the hub on if you do not want too.
Old May 20, 2011 | 04:34 PM
guzzlin_gas
Thanks. I was pretty sure I could... just wanted to make sure I wasn't missing something!
Old May 21, 2011 | 04:05 AM
CPaulsen's Avatar
CPaulsen
Leaving the outer half of the hub off is a really simple way of determining that noise in the wheel if you think a wheel bearing or auto hub problem, The axle snap ring holds everything in.
