IST1: 1989 Ranger Solid Check Engine/Code light
It changed the way it ran suddenly at a stop sign.
It chugged as if it was on one (out of four) cylinders until it died about a 1/4 mile farther on.
~I towed it home.
The code readout is a solid light with a jumper from Self Test Input to pin 2 of the self test connecter.
I can see a timing belt in it but can't tell if it skipped yet.
Any strange mechanical engine noises when it did this????
I believe your year/model has two fuel pumps, a low pressure feed in the tank, a high pressure one on the frame rail under the cab for the fuel injectors, so how is fuel pressure & delivery rate over time???
If no noises & the engine isn't locked up, will it try to run on starter fluid???? If it will, look to a fuel delivery problem. If it won't try to fire, look to a spark problem.
Some thoughts for consideration, let us know what you find.
Can parts stores test an EEC off of the vehicle?
I'd like to solve the code issue before I begin pulling belts off. The timing belt IS a prime suspect, as is the convertor being clogged, but those codes are basic to the whole system.
One thing I can do is clear the computer by disconnecting the battery negative.
The reason I waited so long is because I waited for payday to drop five gallons of gas into it and see what it did. It would suck if I ran it out of gas and that was all it was...
RESULT: It popped and ran like it was on only one cylinder.
Okay - so much for the performance test. As sudden as the way it changed happened it has to be a definite problem of some kind.
* BATTERY is good, and can be charged if needed
What could break or quit while rolling up to a stop sign on a 20 degree uphill? I think only a major timing change would do this, plug failure, or a hole rotted in a fuel line could (COULD! But I've seen those lines and they last longer than thirty years on average)
Of 'course, a bad electrical connection can happen ANY time...
See now - my general trend in thought here is that (Something that can wear out) has worn out.
Rubber, plastic, lubricated parts, etc.
The roll-out on that hill wasn't enough for that skinny fuel tank to feed different... think I PROVED it by pouring five more gallons in on a level place. But why did it even run? And run like that?
The "Stuff that Wears Out" category gets smaller every year.
I think timing belt because it's been at least five years. I only do around 1K mile a year, but that's an old belt under tension.
But electrical stuff goes bad the same way, NO WARNING
Timing belt is in spec!!! It really did line up BINGO with a few more tries.
(I was bumping it into place using 1st gear)
I'm going to go after the cat convertor tomorrow!
Whiskey/Tango/Hotel... I have a spare one for a V6, don't I?
Aah - you guys don't know about my other truck
If thats ok, hook up a fuel pressure gauge to the fuel rail schrader valve & check fuel pressure & fuel pump delivery rate, (volume over time).
If thats ok, hook up a vacuum gauge to it & see what that tells you about the engine mechanicals.
If thats ok, use an inductive timing light to quickly & safely check for spark.
PRESSURE REGULATOR has been added to the list. DITTO vacuum guage.
Light I've got. I was planning that too - what about this?
This truck always did act as if it had a mighty lot of back-pressure. If the cat collapsed internally or got plugged the only way to know is drop it, right?
I wonder if I can pull the EEC/MCU relay or fuse, unscrew the front EGO (OX Sensor), and get an idea of blockage by turning the engine with the starter?
Come to think of it, I wonder if I have a compression guage adapter that is the same size as the OX-Sensor threads? Wouldn't that be cool!
If funds are tight, Harbor Freight has one for about $20, if you wrap it's hose connections with plumbers PTFE ribbon dope, they won't leak & it'll work ok.
Good idea to try removing the O2 sensor as a test to relieve exhaust back pressure, I had forgotten to suggest that.
Review the vacuum gauge tutorial moving graphics illustrations, to see what the meter movement for a clogged exhaust test, looks like. Other vacuum gauge test illustrations there too!!! http://www.secondchancegarage.com/public/186.cfm
Even though I'm one of the old timers here!
That may be part of it - old guy used to points and condensers in the modern world. But I did Electronics for a career in naval aviation!
I actually LIKE the idea of computers in trucks. As long as the inputs are kept to a minimum
By the way - I also patched a split off vac line between the EGR valve and it's controller.
* I really don't like the vacuum tubing they used
There have been times I wished I could run a cannon manifold, headers, dual webers, and a freakin' magneto on this truck....
(Pardon me. That's how I vent...)
I have a neighbor who advised another neighbor to just cut the converter OUT of an SUV of another brand. It never ran right after that and gobbles fuel. You can see unburnt residue all around the exhaust tip...
The EGO (Exhaust Gas Oxygen) sensors have to be in the circuit if the EEC is running in open loop (highway driving) (!)
This "OTHER BRAND" SUV interpretted the lack of input as a lean burn condition.
The front and back O2 sensors have to be at least mounted on a pipe between the headers and mufflers to read anything...
Simple to do. Drill holes and weld on nuts with the right thread as bosses
At the very least they need to still be connected. DON'T JUST DYKE AND STRIP!
OR a 2 banks of 9 each jugs, R-3350-26WC, 3350 cid & 3600 hp normally aspirated, with dual mag ignition & two Champion spark plugs to each cyl, BUT with a dual stage super charger on high blower & alcohol water injection, it'll make 4400 combat hp, from those 3350 cid!!!! Ahhhh what a beast it was, turning that 900 lb, 13.5 foot dia variable pitch Hamilton Standard 4 blade fan, to keep the pilot cool!!!! lol
Yup the AD Skyraider/Spad it was called in later years, was a Mack truck with wings!!!! At 3600 rpm it's intake manafold vacuum was typically about 56-57 inches, now Thats some serious vacuum!!!!!
And they built the props for god knows what all....
The last bay on most nuke carriers has crates of blades for helos, and stored CV props for COD's and E2's!
I SALUTE YOU ACROSS THE NET SIR!
Civvy life is kinda boring, innit?
80% came out in 5 minutes once it was on jackstands. ~ Not a lot left of the old muffler.
I didn't see anything that would cause backpressure though - so now I'm hacking away with a tailpipe cutter (in a real tight spot, naturally) because the truck has a fully welded system. The donor truck parts are already detached...
NOTES:
*The CAT on this truck has NO SENSORS mounted to it. The OXY sensor is at the bottom flange of the stock header.
* Overall length of the cat is about ten or twelve inches.
* I see no other sensors further along the pipe. Hacking the convertor out should change little, if it comes to that
9JULY update - sorry gang. I dunno what that pipe is made out of but it's taking a bit more than an hour, and I got rained out.
Should be dry today - 'nuffs enough
