Old May 19, 2011 | 02:00 PM
shorty2tall's Avatar
shorty2tall
600 750
I'm looking at doing a new carb and intake was wondering 600 or 750 carb?
It's just my dd sone mudding and I just want more power.
I've got headers and full exhaust. It's a 351m and a 4speed.
Also is the stock fuel pump enough or should I upgrade to the mr. Gasket 80gph?
Old May 19, 2011 | 03:48 PM
Sleepy445FE's Avatar
Sleepy445FE
600cfm is plenty for your 351m. It would be way over carbed with a 750. The stock fuel pump should keep up. If you're wanting more power I would think an intake would be in order to make use of the new carb. That and a straight up timing set (most post 72 factory timing sets are retarded a few deg.).
Old May 20, 2011 | 12:02 AM
shorty2tall
Ok ya I'll be getting a new intake with the carb in gunna get a kit from summit or jegs and I just did a bottom end rebuild so idk if I wnt to do timing again yet lol. But if I do should I retard or advance it? And would a cam be worth it I'm thinking about doing a full rebuild. Or maybe a 460 swap but idk worse mileage
Old May 20, 2011 | 07:50 AM
jmm's Avatar
jmm
i agree 750 would be over carberd. i had a 750 on a 400 and way to rich.
Old May 20, 2011 | 10:18 AM
KrautBurner's Avatar
KrautBurner
+1
the only way you'd want a 750cfm on a 351 is if you were spending most of your time above 4500rpm
otherwise you'll be loading up below 4K
(I had a 750 4bbl on my 79 Camaro with a built 383, it ran pig rich around town, but when I opened her up, she came to life about 4K, and had gobbs of power to redline. way too much carb for street driving on a small block)
you may consider a 625 Street Deomon
I'm a fan of them
Old May 20, 2011 | 10:23 AM
KrautBurner
take a look at a carburetor calculator Carburetor Size Calculator
you take your engine size
max rpm
and efficiancy (probably about 80-85%)
I put in 351ci
6Krpm
85%
and it says 518cfm
I put in 460ci
5500rpm
and 85%
and got 622cfm
BGF100
Oct 28, 2016 06:27 PM
blk450er
23
May 29, 2016 02:12 PM
Fordracer2001
24
Jun 4, 2008 10:03 AM
Clifford II
19
May 8, 2004 03:41 PM
