SES Code Help
Old May 18, 2011 | 07:31 PM
Schmitty133's Avatar
Schmitty133
SES Code Help
I have an'05 Excursion 6.0. The SES light came on yesterday and I checked the code at Auto Zone. It gave me a P1335 code. It said something about Manufacturer Ignition Control or Misfire? I also found a P0404 EGR Perf/Range code? Can anybody help with this? Just curious what it means, and what could be causing it? Thanks!
Old May 18, 2011 | 07:54 PM
BLADE35's Avatar
BLADE35
there both egr codes
replace your EGR valve
Old May 18, 2011 | 07:59 PM
Schmitty133
Can I just unplug it for the time being and erase the code? Or will it come back with it unplugged?
Old May 18, 2011 | 08:04 PM
BLADE35's Avatar
BLADE35
NO dont unplug it on that year of truck it compleates the circut to the fan clutch
you might overheat it with the egr unplugged
you could try and clean it
even if you deleate the egr system you will still need the EGR valve plugged in for fan operation
Old May 18, 2011 | 08:31 PM
Schmitty133
Is it safe to drive like it is? Will it wreck anything? My wife is supposed to leave for a 1000 mile weekend road trip to Missouri tomorrow!
Old May 18, 2011 | 08:35 PM
BLADE35's Avatar
BLADE35
it could run bad if it gets stuck open position just
one of the codes was EGR range/performance
Old May 18, 2011 | 09:02 PM
Schmitty133
It doesn't seem to be running bad right now. I'll see if I can get it out to clean it before she leaves. Thanks!
Old May 18, 2011 | 09:17 PM
BLADE35's Avatar
BLADE35
read this thread
https://www.ford-trucks.com/forums/4...egr-valve.html
click here^^^^^^^^^^^^
