Little help??
Old Oct 6, 2011 | 07:49 PM
grantpage's Avatar
grantpage
I would stick with the truck and stick with this site and these guys will help keep you out of trouble. Seems like a lot of problems can be prevented if the truck is monitored properly. And at any point if you feel you have a problem just post in here and get instant feed back, most every problem with a 6.0L has been dealt with here.
Old Oct 12, 2011 | 03:23 PM
JLM's Avatar
JLM
thanks! your correct, the help here is fantastic! So.... how do I seperate the oil cooler from the upper housing? I have the assembly on the bench and have taken 2 internal bolts and 2 nuts off but it doesn't seem to want to budge.
Old Oct 12, 2011 | 04:00 PM
05 f250 6 inch lift's Avatar
05 f250 6 inch lift
Where the EGR cooler hose is. Take the 2 torq bit screws out an then u can pull it off. Made mine easier to get out. Should b able to just push it out then. But may have to push HARD. If not then block of wood an hammer.
Old Oct 12, 2011 | 04:05 PM
npccpartsman's Avatar
npccpartsman
The kits I've used had instructions on how to remove the cooler assy from the housing. Basically it says to suspend the housing on blocks with the cooler between them then use a socket and hammer to drive the cooler from the housing. It takes a couple of pretty stout hits to move it. It's going to have to be stripped down to this (bottom center picture) http://dan.prxy.org/Truck/6L_bible_h.../Page_024.html
Old Oct 12, 2011 | 05:31 PM
rdunagan's Avatar
rdunagan
haha yea they are a *&(*^ to get out! i just took a hammer to mine but i was also careful not to hit the housing. the new one i just took the vise on the bench and slowly pushed it in. make sure to clean everything outta there and make sure no debris went past that screen or else you might be replacing an IPR valve
Old Oct 13, 2011 | 06:14 PM
JLM's Avatar
JLM
thanks guys. I really really wanted to just BEAT it out so I put down the hammer and decided to ask the professionals.
Old Oct 25, 2011 | 04:53 PM
JLM's Avatar
JLM
So............I'm in the process of going back together with this thing. I took the battery's out of it a year ago and put'em in my tractor. Once I get them back in the truck is there anything special I need to do to the computer system to make it run? thanks
Old Oct 26, 2011 | 05:11 AM
npccpartsman
No there isn't. It won't lose it's memory.
Old Oct 26, 2011 | 03:43 PM
zhilton's Avatar
zhilton
The only thing I'd do would be cycle the key a couple of times to make sure the fuel system is good & primed. But that's just me.
Old Jan 3, 2012 | 02:06 PM
JLM's Avatar
JLM
Thanks for all the help folks!! you and this sight are great. Its on the road with about 1k miles on it.
Lance Amatulli
Feb 7, 2015 06:43 PM
pa-12
Mar 11, 2014 11:40 PM
ssquints999
Jan 28, 2009 06:51 PM
Sycostang67
Oct 12, 2005 10:00 PM
