Pinion Angle
Old May 17, 2011 | 08:20 PM
abrauer's Avatar
abrauer
Pinion Angle
I know this question has been asked before, I just can't seem to find it. I swapped in a 9 inch out of a 63 f-100 was wondering what the correct pinion angle should be? Running a 302/c4.
Thanks,
Adam
Old May 17, 2011 | 09:23 PM
CharlieLed's Avatar
CharlieLed
The engine/trans should be pointed somewhere around 3 degrees downward. Measure the angle at the tailshaft. Take whatever angle measurement at the tailshaft and use this angle for the pinion...only have the pinion pointed up. The easiest way to think about it is that you want the tailshaft and the pinion to be parallel. Lots of charts floating around the net if you need a picture.
Old May 18, 2011 | 12:07 AM
Jeff and Nicolle's Avatar
Jeff and Nicolle
not that i want to guinea pig this but how bad can it be when there is a slight angle difference to parallel? the 4X4 boys must eat u-joints weekly!
i am working on my pinion angle too, its really hard to pinpoint what is going to be correct in my case cause there is no wieght from bed,cab, etc. i am gonna have some rake back to front, tire size,etc. but it tough to know exactly
Old May 18, 2011 | 04:56 AM
sdetweil's Avatar
sdetweil
generally you will be ok within a degree. which is less than u would get with all the changes due to weight..
sam
Old May 18, 2011 | 05:11 AM
cruisetopdown's Avatar
cruisetopdown
There are apps out there for smart phones that are free, that have the ability to calculate degrees of angle.....(clinometer) try it, you'll like it....
w
Old May 18, 2011 | 07:46 AM
55 f350's Avatar
55 f350
i got notes from a 79 i parted , a 74 , a 70 a 56 , two 55's and my 1 ton 55 and my baby the 53 and all were at 4degrees according to what i got down in frony of me . 4 degrees up that is ............................ when i put the 53 back together and lowered it'll be reset there .
Old May 18, 2011 | 09:18 AM
Old F1's Avatar
Old F1
Yep, 3 degrees up on the pinion. It is my understanding (and experience) that the engine / trans tilt is built in to the intake manifold by the manufactures, the carb base of the intake should be level and the tailshaft angle will be at 3 degrees.
Old May 18, 2011 | 09:23 AM
tinman52's Avatar
tinman52
Welder User
The actual degree number doesn't really matter as long as the pinion shaft and the trans output shaft are on the same plane......in other words, parallel.
Old May 18, 2011 | 11:12 AM
rockher_man's Avatar
rockher_man
Lightbulb Driveline PHASING....
Thanks,
Adam
302 block & C4 combo.....sweet...thats is what I'm working with...
...for now...unless somebody happens to leave an AOD on my front
porch......
...until then I'm gonna keep pluggin' away to make it work with the
3.89 Trac-Loc in a FRANKENINE (nick-name for this PITA) rear-end
pulled out of a wrecked '70 F100 along with the original C4...and
topped-off with a vintage '63 Buddy Barr/Holley SBF tri power......
C-4 ratios are: 2.46:1, 1.46:1 and 1.00:1… reverse is 2.19:1
Sooooo...with a 3.89 ring & pinion...and 15" tire/wheel combo
around 28" diameter I figured I'll be spinning right around
3268 rpm at 70- mph......ouch...
DRIVELINE PHASING......
https://www.ford-trucks.com/forums/850854-setting-pinion-angle-2.html
Look at the diagrams in post #19...clear things right up......
Thought this might help......
Old May 18, 2011 | 01:45 PM
ZOOT's Avatar
ZOOT
Three degrees is what I did and it works fine. Don't sweat it too much cause you can always get a wedge to put between the rear axle and the spring to fine tune it once the the body is on. Many suppliers sell these shims in degree incriments.
Old May 18, 2011 | 03:35 PM
jniolon's Avatar
jniolon
old and in the way
DRIVE LINE PHASING
this might help
john
Old May 18, 2011 | 10:47 PM
Mervy49's Avatar
Mervy49
Originally Posted by jniolon
DRIVE LINE PHASING
this might help
john
For pinion and transmission placement You have the best drawings and explanations for this task on this site..
mervy
justcruzin125
Jun 27, 2017 01:18 PM
Outlaw56
Feb 23, 2017 07:58 PM
Blinker Fluid
18
Apr 26, 2014 09:34 PM
glosol
15
May 22, 2011 06:33 PM
benmoderow
32
Feb 23, 2010 10:14 PM
