4:88 Gears
Old May 17, 2011 | 07:40 PM
OneTon4Fun's Avatar
OneTon4Fun
4:88 Gears
I hear F450s are running 4:88 gears. Is this true?
Is anybody running 4:88s on their F350?
I pull 18K pounds and the truck is a dog from a stand still. Most tractor trailers beat me off the line. I run 4:10 and think 4:88 will work better. I don't care for top end speed or fuel milage as long as it is not too bad.
thoughts?
Old May 17, 2011 | 08:11 PM
mah77's Avatar
mah77
Need a little more info: What year truck? What size tires? Tuner?
Old May 18, 2011 | 07:04 AM
OneTon4Fun's Avatar
OneTon4Fun
F350, innovative diesel tunes, stock DRW tires right now. If I have too much gear with the 4:88s I can go to taller tires.
Old May 18, 2011 | 08:12 AM
tex25025's Avatar
tex25025
I know you said you weren't all that worried about it, but your top end speed would be reduced by going to 4.88s as well as MPG if you push that top end speed quite a bit. I run 4.30s haul ~16k extremely often, particularly this time of year which is why I'm not on here as much as I am during the fall and winter months.
Also I wouldn't be running tunes on a 4.88 geared truck. Way to easy to push the upper limites of the truck with tunes.
4.30s would help you quite a bit of 4.10s. 4.88s is too much of a jump (in my opinion). Also having 4.30s helps keep everything the way you were used to it as far as basic driving goes, speed on the interstate, mpg etc.
Ryan313
Dec 22, 2013 06:44 PM
mrdoughnut
Modular V10 (6.8l)
Dec 23, 2011 03:10 PM
Carny
Feb 15, 2011 09:26 AM
mregister
Sep 12, 2009 10:20 AM
trackdayhauler
Modular V10 (6.8l)
16
Jan 25, 2009 07:36 PM
