ive been in the 99-03 diesel for awhile but had to let the truck go. 15mpg was eating me up. i now have a 02 supercrew f150 with the 4.6 and 93k. its completly stock for now. ill work on the avatar and sig later..
have a question already. when i push the button to move my pedals the gas moves in and out like it should. the brake trys but doesnt move. any ideas??
Reason: forgot something.
There is one motor attached to the brake assembly.
Off the end of the motor shaft is a flex drive cable over to the gas padel screw drive.
If the gas pedal only, moves, one/ both gears off the end of the motor that drives the brake assembly screw drive is broken or slippping.
you have to remove the motor to see what has happened.
Easy to see what happens if you get under and operate the location switch.
Good luck.
