engine size and towing
Old May 17, 2011 | 04:43 PM
sjer's Avatar
sjer
Could a 4.6 tow a 5th wheel with a 500 hitch weight and over all weight of 2800 unloaded (a 20' lightweight 5th wheel trailer). And how can you tell what size engine is in a 2005 crew cab. I paid cash from a private owner, was told it was a 5.4 but I don't know how to check it to be sure.
Old May 17, 2011 | 10:05 PM
jpurvis79bronco's Avatar
jpurvis79bronco
4.6 should pull 2800lbs without a problem, but being it is a screw, the payload capacity isn't the greatest to start with and loaded with people and gear +500lb tongue weight might get close to the payload rating. It should say on the under side of the hood what motor you have, the intake/air box is different on the 5.4 too. The payload capacity should be listed on the drivers side door IIRC.
Old May 18, 2011 | 05:20 AM
MCDavis's Avatar
MCDavis
The first picture is the engine bay of the 4.6L
Second picture is the engine bay of the 5.4L
Old May 18, 2011 | 12:57 PM
BackwoodsF150's Avatar
BackwoodsF150
It's not a surefire way, but just check the F150 badge, it'll say 5.4 Triton, or just Triton if it's the 4.6
Old May 18, 2011 | 01:05 PM
MCDavis's Avatar
MCDavis
The top of the air filter box says "5.4L Triton" also...dead center of the 2nd pic I posted earlier.
Old May 18, 2011 | 01:07 PM
Fox Fader's Avatar
Fox Fader
I second that.
Old May 19, 2011 | 02:27 PM
hcbph's Avatar
hcbph
Engine size
Isn't it on the door sticker? There's also a website (which I can't find right now) that you plug in the s/n of the truck and it will show the window sticker on it for truck around 5-7 years or newer.
Paratrooper84
6.7L Power Stroke Diesel
47
Aug 14, 2012 08:39 AM
cameronm
Mar 11, 2011 05:32 PM
02towwannabe
All Things Towing
32
Aug 22, 2003 01:53 AM
Jetsfan68
All Things Towing
Jun 5, 2003 12:08 AM
robnfl
Aug 24, 2002 12:37 PM
