Sponsored by: Real Truck
Shocks
Old May 17, 2011 | 08:32 PM
VTX1800rider's Avatar
VTX1800rider
Originally Posted by Robs06SuperDuty
just jack up one side at a time, remove the tire, unbolt the bottom shock bolt, then unbolt the stud on the top of the shock. Installing the new one in reverse order of this.
Or if you're lucky like me, the studs will twist off when putting some arm torque on them. This happen with the factory Fakecharos. Even had soaked them with PB Blaster.
Old May 17, 2011 | 08:40 PM
Robs06SuperDuty's Avatar
Robs06SuperDuty
haha musta ate your wheaties that morning!
Old May 17, 2011 | 08:45 PM
tolliewolly's Avatar
tolliewolly
Ok robs. You have me convinced. I will order them tomorrow with the company card.
I really appreciate all of your replies. I figure shocks will go bad around 100'000 miles as a generic term. It's almost time so it's better to be safe than sorry.
Thank you again!
Old May 17, 2011 | 08:54 PM
Robs06SuperDuty
not a problem man, dont be afraid to ask questions on here. but also dont be afraid to use the search feature. I think theres a discount code you can use at shockwarehouse, " Ford5 " I think it is.. you'll get 10% off I beleive.
Old May 17, 2011 | 08:58 PM
tolliewolly
I did search and I know there's a lot but sometimes the trend changes so in is case I just wanted to throw out there what was the current thing to buy when wanting to change shocks on a DRW and pull the ranchos out.
I will order tomorrow and hopefully they will be here by the weekend to change.
Old May 17, 2011 | 09:07 PM
VTX1800rider
Funny thing was I have two torn rotor cuffs. That was my biggest concern, finishing one off. I had soaked the studs with PB two days prior. I had set up my saws all to cut the studs as a last resort. First try with some leverage. SNAP. Went over with the other side.. SNAP. Used an impact on the bottoms. Love the Bilsteins too. Huge difference.
Old May 17, 2011 | 09:23 PM
Robs06SuperDuty
haha thats awesome! how manys miles were on them when you switched em out?
Old May 18, 2011 | 08:08 AM
Spike Engineering's Avatar
Spike Engineering
My current truck is a 05 F350 DRW and I replaced the stock shocks with Monroe Reflexes about 7 months ago. There was slight change in the ride because the stock shocks needed replacement. But the change was only slight.
I didn't expect much of a change because when I changed the shocks on my prior truck, there wasn't much of a change either. On that truck (F250 King Ranch), I replaced the stock shocks with Bilsteins. I was somewhat surprised that the ride wasn't a little more stiff because the prior Lightnings I owned came with Bilsteins and the stock ride was harsh, but primarily because the the rear shocks were overdamped.
Just this past weekend, I replaced 7 month old front shocks on the F350 with new Bilsteins.
I'll have to admit, prefer the ride with the Bilstein shocks. It's a little more firm but not too firm. I wouldn't consider the ride harsh.
I'll be swapping out the rears this weekend (replacing the Monroes with Bilsteins).
The fronts aren't difficult to change. The drivers side is easy. Just turn the steering wheel full lock right and you can access the shock tower from the wheel well or the engine bay. The right front (passenger front) is a little more difficult. Just turn the steering wheel full lock left and access the shock tower from the wheel well. Don't bother trying it from the engine bay - it's just too congested.
Old May 18, 2011 | 10:39 AM
Rancho Suspension's Avatar
Rancho Suspension
Former Vendor
the Rancho's on your truck arent actually rancho, they're Ford shocks painted white and slapped with a Rancho sticker...
get yourself a set of Bilstein HD's from shockwarehouse.com you wont be dissapointed. I've had mine on for about 60K now. the stock ones didnt last 25K and I bought the truck new.
They are actually Rancho shocks.
Old May 18, 2011 | 04:58 PM
maverick22's Avatar
maverick22
No offense, but I'm not sure I'd be bragging about that. Those shocks that came OE don't have the best reputation. Always been surprised Rancho would put their name on them.
Old May 18, 2011 | 05:05 PM
Rancho Suspension
Former Vendor
None taken, some people like a "firmer" ride on their truck, while others like to try and tame a truck down. My truck empty rides different than full or towing my Jeep, that is why I like the 9000's. I can play around with them. Thanks!
Old May 18, 2011 | 05:06 PM
jc8825's Avatar
jc8825
They're no worse than other OE style shocks out there. They are marginally better, but better all the same, than the standard shocks the non-FX4 package trucks get.
Old May 18, 2011 | 06:47 PM
  #28
VTX1800rider
I had about 65k on them.
oldtimr
Apr 10, 2013 10:08 PM
prorad
Jan 12, 2013 07:22 PM
Bsentman888
Mar 5, 2012 09:25 AM
ColoradoF350
Dec 23, 2011 02:53 PM
A H DEVELOPMENT
Nov 15, 2011 01:12 PM
