Sponsored by: Auxito
Fuse #19 Blowing
Old Aug 29, 2011 | 11:45 AM
Bluegrass 7's Avatar
Bluegrass 7
Bill, I can't help you anymore except by bring to you electric theroy that I am an expert on as far as this forum is concerned. I have been doing it more than 60 years if that means anything.
Rather than get into a debate about it I will not answer again but leave you with this common sense.
A fuse, any fuse absolutely does not blow unless there is to much current flow through it. If the fuse does not blow until you plug a trailer connector in, it has to be the trailer causing the excess current to flow.
Again having anything else on has no 'electrical' connection to any other circuits (In fault free wireing) . Why would it?
Even after plugin without blowing, the first time you use the turn signal it should blow it again but you say no. How come?
There may be a relay involved in the distrubition box as well that may have some type of fault.
I added trailer harness, fuses and relay to my truck with both 4 pin and 7 pin outlets plus electric brake controller and have never had any type of reaction like you have.
I have towed large trailers with electric brakes and still tow small trailers with 4 pin trailer lights.
It's not a Ford fault in design.
You have a specfic fault to your situation and have to run the reason down.
Good luck with it.
Old Nov 25, 2011 | 05:55 PM
murraydav's Avatar
murraydav
any logical reason for passenger side brake light fail.
Just bought a 1999 f-250. Gently easing it back to normal. One niggle has popped up. Right rear tail light brake at first was intermittent along with the high mount brake lamp. Now it will not show brake. It will show running light, it will not show signal. The bulb is good. The socket is good Disconnecting at the connector near the left wheel and testing with a probe light I find blinking on only one wire. The power is not coming from the front of the truck to feed right side. The fire wire at the right rear is orange with a blue tracer. Next: Probing under the hood under the air intake I find an orange wire with a blue trace. Test light produces flash when the right signal is on. Therefore orange-blue wire is hot under the hood but not at the connector. Is there anywhere to look for a wiring diagram for the drop nosed f-150/250
Old Nov 25, 2011 | 08:49 PM
Bluegrass 7
There is a harness plugup toward the rear.
This is were the harness plug is for the wire option of trailer with 7 pin socket or no 7 pin socket.
Follow it toward the front from the driver side rear till you come to the plug and test there for an issue.
Should be somewhere over the wheel well area inside the frame.
Good luck.
fireeater91
29
Dec 31, 2019 03:05 PM
Magnumu
2009 - 2014 F150
Dec 28, 2016 11:31 AM
fireeater91
Jul 20, 2012 09:39 PM
DemonRace6
Jul 27, 2011 09:24 AM
rost495
Electrical Systems/Wiring
Oct 27, 2008 09:03 PM
