99 f350 7.3l 4x4 rearend diff fluid questions
Old 05-16-2011, 09:10 PM
bubba_v2008's Avatar
bubba_v2008
bubba_v2008 is offline
i have a 99 f350 7.3l 4x4 i need to change the front seal on the rearend i know it takes 75w 140 synthetic gear oil i plan on using the royal purple my question is how many quarts does it hold from being complely empty ive put alot of miles on this truck since i got it and should change it while im down there the tag on the rearend say "3 S 409 E
L73 10 5 9F24"
and if any bodys knows which rearend do i have any help will be appriatied thanks for your time.
Old 05-16-2011, 09:43 PM
bubba_v2008
well i believe its a 3.73 gear ratio rearend but how much fluid do i need to buy that stuff is expensive
Old 05-16-2011, 10:05 PM
Cell's's Avatar
Cell's
Cell's is offline
your best to have 4 for sure and 5 to make sure if you happen to spill when filling .
Old 05-16-2011, 10:08 PM
clintbonnie's Avatar
clintbonnie
clintbonnie is offline
While you are under there, check the breather hose from the rearend. My seal was leaking awhile back and it was because the breather was completely plugged by an insect nest.. The rearend builds up pressure and the front seal is the weak point and it starts leaking..
My manual says 6.9 pints for a 10.5 axle, F250/F350.
If you need a copy of your owners manual.. see:
https://www.flmowner.com/servlet/Con...e&ord=42948682
Old 05-16-2011, 11:18 PM
big poppa's Avatar
big poppa
big poppa is offline
If your going with Royal Purple fluid like I did, get yourself a 5 oz bottle of Motorcraft friction modifier, it's only about 5.00-7.00 dollars, cheap insurance. I had to add about a half bottle because the modifier that was in the RP wasn't enough, I had some tire scuff going around tight turns, half a bottle was all I needed.
Old 05-16-2011, 11:32 PM
Izzy351's Avatar
Izzy351
Izzy351 is offline
Also look into the 08+ diff cover. I love mine! I think it holds a little less fluid with that cover because I bought 4 quarts and had a full bottle left after filling. I used RP with no further friction modifier needed.
Here's what it looks like:
dumptruck denny
02-20-2016 07:48 PM
gtotiger65
16
09-05-2015 09:33 AM
bubba_v2008
1999 to 2016 Super Duty
05-17-2011 03:22 PM
3wheeler
01-13-2008 12:26 AM
ANG&STEVES F350
12-09-2006 08:57 AM
Quick Reply: 99 f350 7.3l 4x4 rearend diff fluid questions
