1978 - 1996 Big Bronco
six inches
Old May 16, 2011 | 05:25 PM
ExtrmZ's Avatar
ExtrmZ
six inches
Has anyone installed a six inch lift on their bronco? The company mentions lengthening the driveshaft. did you do this and if so how?
was there any shimming of the transfer case needed?
Old May 16, 2011 | 08:52 PM
Edgethis's Avatar
Edgethis
There is plenty of lifted Broncos with 6 inch lifts. You shouldn't need to lengthen anything at 6 inches for a street truck, but if you actually use the full motion of your suspension I'd invest in some extended brake lines. The drive shafts should be alright.
Old May 17, 2011 | 10:00 AM
Kemicalburns's Avatar
Kemicalburns
i wheel my bronco alot and the brake lines do not need any attention with a 6" lift. i have cycled my suspension and have found the shocks limit me more than anything.
Like Edgethis said, driveshafts will be fine
Old May 17, 2011 | 12:08 PM
ExtrmZ's Avatar
ExtrmZ
i didnt think the drive shafts needed to be touched, they didn't on my 4in on my pickup anyway.
Well the kit comes with extended brake hoses, so it looks like thats the one,
Thanks guys
Old May 17, 2011 | 11:51 PM
greystreak92's Avatar
greystreak92
For suspension lifts UP TO 6" total height increase the drive shafts need NOT be lengthened. Anything OVER 6" will or you run the risk of the slip shaft on the rear in particular running out too far and shearing off the ends of the splines.
Keep a close eye on the kit recommendations for axle shims though as it may be necessary to increase shim angle to avoid u-joint bind. This is dependent on the amount of articulation the lift will actually gain you. With most 4" lifts the factory 3º shims just need to be re-used. A 6" lift may need more than that. Consult the manufacturer of the lift.
