Ok guys, need some help
Also - is the EGR valve the original one? If so, you probably should get a new one. Ford improved some of the design features of the valve in 2008.
Also, your tuner may be causing some issues - generating a lot of carbon, etc.
If you are having a problem keeping the boot on something like this may help
http://www.turbohosefix.com/
These boots are as good as they get and the ring is used to keep the boot on you run the clamp over the middle of the ring then get it tight it will stay.
http://www.dieselsite.com/index.asp?...S&Category=616
<TABLE border=0 cellSpacing=0 cellPadding=3 width="100%"><TBODY><TR><TD class=yiv1122098120header bgColor=#e3e3e3></TD></TR><TR><TD class=yiv1122098120info><TABLE border=0 cellSpacing=0 cellPadding=0 width="100%"><TBODY><TR><TD vAlign=top width="100%" align=left><TABLE style="BORDER-COLLAPSE: collapse" border=0 cellSpacing=0 cellPadding=2 width="100%"><TBODY><TR><TD vAlign=middle width="20%" align=center></TD><TD vAlign=middle width="80%" align=left>
2003-2007 6.0L Turbo Outlet Angled Replacement Boot
Product Part #: DSB6TO
(Qty: 1 x $131.00)
</TD></TR></TBODY></TABLE>
Dieselsite Turbo Hose Retaining Ring - 6.0L Turbo Outlet Hose - 2.5" ID Hose
Product Part #: BR25
(Qty: 1 x $8.50)
2004.5-2007 6.0L DIESELSITE Intercooler Boot Kit
Product Part #: DSIBK6
(Qty: 1 x $78.00)
pop
</TD></TR></TBODY></TABLE></TD></TR></TBODY></TABLE></TD></TR></TBODY></TABLE>
