Truck jerking
Old May 16, 2011 | 10:39 AM
LaBlacky's Avatar
LaBlacky
Truck jerking
Hey guys I'm new to this site and my truck is jerking really bad. It is a 6-speed and will jerk when I am giving it gas and letting off the gas. Sometimes it will give me a dead spot, and then respond. About a month ago i was going down hill and was coming to a stop sign, put my clutch in and usually idles down, in this case the truck died, after i stopped it started right back up. I have tried several different things, i changed the pedal assembly about a year ago and thought that would have corrected this issue but no it still happens. I have also had the Cam Shaft Sensor replaced by ford. Can you please help me out I would love to get this fixed and have my truck run smooth again.
Old May 16, 2011 | 12:20 PM
clintbonnie's Avatar
clintbonnie
When the truck jerks, do you get a 'Check Engine Light"? Can you have someone read your fault codes ?
A big welcome the forum..
Old May 16, 2011 | 12:54 PM
LaBlacky's Avatar
LaBlacky
Thanks for the welcome, I don't get the Check Engine Light on when it happens, that is why I am having a tough time figuring out what is wrong with it. I will check the codes with my Super Chips Programmer and post the codes if any here this afternoon when i get home from work.
Old May 16, 2011 | 09:26 PM
LaBlacky's Avatar
LaBlacky
Ok guys read the codes and only one I have is P0603. To my knowledge this is the code that means that i have a programmer installed, correct? Please guys help me out I would like to get this taken care of.
Old May 16, 2011 | 09:40 PM
Deluxe06's Avatar
Deluxe06
4000 rounds a min
Have you ever checked your UVCHs (Under Valve Cover Harnesses) one could have come loose.
Old May 16, 2011 | 10:02 PM
clintbonnie
Yes, that is correct. My thought it is not the UVCH.. It usually throws a code like P1316.. You might consider going back to stock and trying that..
Old May 16, 2011 | 10:37 PM
LaBlacky's Avatar
LaBlacky
Will do guys I will check the harness under the valve cover and also try running it in stock for a few days. What really troubles me about the problem is it does it a lower speeds, or when you let go of the pedal or acceletarte. Also when you have it in cruise control and turn it off, or resume it does it. Once the truck is in going it works just fine, it feels like the if the throttle gets stuck then breaks loose all of a sudden. And when you accelerate it will jerk making the RPMs jump up and down.
Old May 18, 2011 | 08:53 AM
LaBlacky's Avatar
LaBlacky
So guys checked the harnesses and they look good, and tried running it in stock mode and still does it. Any other suggestions? Please help me out!!!!!!
Old May 18, 2011 | 10:26 AM
clintbonnie
Was your problem of the engine dieing and jerking happening before Ford replaced the CPS ?
Old May 18, 2011 | 10:39 AM
Deluxe06's Avatar
Deluxe06
4000 rounds a min
I see you are in TX maybe someone near you has AE and will be able to help you out and hookup to your truck and will be able to see what is going on. Any Takers????
Old May 18, 2011 | 11:04 AM
LaBlacky's Avatar
LaBlacky
@ Clint yes the problem was happening before the CPS was replaced, so I am ruling that out somewhat i know sensors can be faulty so I might try another one just to be positive. I have read a couple of treads and think I am going to try disconnecting the fuel filter canister heater, and then if that doesn't do anything, try and replacing the TPS to see if that fixes anything.
@Deluxe06 yes i am in San Antonio TX, and excuse my ignorance what is an AE? And yes if anybody would like to help please help me?????????
Thanks to all of you!!!!!!!!!!!
Old May 18, 2011 | 11:19 AM
clintbonnie
AE ... see:
Riffraff Diesel: AutoEnginuity Total Ford Enhanced Bundle
Old May 18, 2011 | 11:38 AM
LaBlacky's Avatar
LaBlacky
Cool thanks I hope some one has one around here and can help me out to see if something comes up. I read my DTC's with my Super Chips programmer but nothing really came out. I will wait to see if any pop out this afternoon after running it in stock for while. I will keep you posted to see what happens.
Thanks,
Old May 18, 2011 | 07:29 PM
Deluxe06's Avatar
Deluxe06
4000 rounds a min
Here's a bump for help.
JGuillen99
1997 - 2003 F150
Mar 15, 2015 05:17 PM
Joco4x4
2004 - 2008 F150
Feb 27, 2013 08:49 PM
Kim's Hipster
Mar 23, 2011 03:46 PM
volfan945
Nov 1, 2004 03:45 AM
parks911
15
Jun 25, 2004 05:48 PM
