Dyno'd my v10
Old May 17, 2011 | 04:07 PM
Paultv's Avatar
Paultv
I don't think that was an excursion though, my excursion would NEVER do that.
Old May 17, 2011 | 04:13 PM
howler4x4's Avatar
howler4x4
Originally Posted by WE3ZS
I don't really care about high HP, but I want all the torque I can get though! My buggy's main duty is as a tow vehicle.
X2 - And the dyno chart shows a nice flat TQ curve, up till about 4K.
Old May 17, 2011 | 06:31 PM
VaSheriff's Avatar
VaSheriff
I am of the opinion that an Excursion would do much worse than the Expedition in the video.
Old May 17, 2011 | 06:46 PM
william_04_x's Avatar
william_04_x
Check out this crash test dummy, err I mean driver, in his RZR. Watch closely as he gets spit out the back of the cage, and gets laid out on the ground.
YouTube - (HD) WORST Polaris RZR CRASH EVER - ejected
Old May 17, 2011 | 06:59 PM
Stewart_H's Avatar
Stewart_H
Originally Posted by ecoastkid
I'll prob do a CAI, y-pipe, muffler, and tune it with my sniper setup and call it a day.
If I can find a sweet deal on long tubes then I might go that route but we'll see what comes up.
...and it begins!
Originally Posted by TXtinct
Are those Bugle Boy jeans they are wearing?
Stewart
Old May 17, 2011 | 09:23 PM
Dubbs19s's Avatar
Dubbs19s
Glad you have some baseline numbers to work with. If you are doing any mods and want to dyno again..make sure you go back to the same dyno to run it again. Every dyno is different, and going to the same one will give you a better idea if the mod was worth it or not.
Next time you go, try to get a full pull in third gear. Second gear isn't a 1:1 ratio and the torque multiplication can tweek the actual numbers.
Old May 17, 2011 | 09:36 PM
gr8scott72's Avatar
gr8scott72
How about cracked open from a Corvette like an egg:
YouTube - Corvette crashes at 165mph!!!
Old May 17, 2011 | 11:06 PM
TXtinct's Avatar
TXtinct
You'll shoot your eye out
Good stuff.
YouTube - Golf Cart Crash
Old May 17, 2011 | 11:07 PM
TXtinct's Avatar
TXtinct
Guess I don't know how to post a vid...
Old May 18, 2011 | 06:16 AM
ecoastkid's Avatar
ecoastkid
Originally Posted by VaSheriff
I guess I am gonna show my age now. But, I just can't get real excited about having 400 to 500 horsepower in something as large as an Excursion.
Originally Posted by jasonodsky
I think the HP is more about braggin' rights than anything else. But to each owner, his own.
Thanks for you input I guess but did you guys actually read the thread? Who's looking to make a race car out of excursion?
Thats the only dyno I ever use as its owned by a good friend...lol
No such thing as a third gear pull on an excursion unless you remove the speed limiter. That will come with time. As a side note, While not exact, you would be surprised at how close the numbers come out regardless of which gear you do the pull in. We have dyno'ed hundreds of cars on that thing and found this through personal experiance.
Old May 18, 2011 | 06:22 AM
fordboy67's Avatar
fordboy67
The link worked for me, no problem!
Old May 18, 2011 | 04:56 PM
VaSheriff's Avatar
VaSheriff
TV sensationalism. The Corvette in the above video was NOT going
165 mph if the Crown Victorias were keeping up with it.
Old May 18, 2011 | 06:09 PM
  #28
william_04_x
Good catch, Sheriff. So how fast can a LE spec Crown Vic go?
Old May 18, 2011 | 07:06 PM
  #29
ecoastkid's Avatar
ecoastkid
It depended on the rear gear ratio (One for highway and one for city applications)..but the highway pursuit one was somewhere around 132 and the city one 125...IIRC. Been a long time since I read an article about them so my memory could be a bit fuzzy.
Old May 19, 2011 | 07:21 AM
  #30
Johnny Langton's Avatar
Johnny Langton
Depends on the year model, and what driveshaft was in it.
The 2006-present Police Interceptors equipped with a 3.27:1 and a 3.55:1 axle from the factory. 3.55 equipped cars are electronically limited to 120 mph due to the lower driveline-critical vehicle speed, while the Police Interceptors equipped with a 3.27:1 rear axle ratio have generally been limited to approximately 135 mph.This compares to 110 mph for the "civilian" model.<sup id="cite_ref-5" class="reference"></sup>
Ford used an aluminum metal matrix composite driveshaft for the 1993–2005 Police Interceptors as a measure to allow safe operation at over 150 mph, but it was more expensive than the regular aluminum driveshafts. Ford reintroduced the 3.55:1 rear axle ratio in the 2006 model year Police Interceptors, and set the speed limiter at 120 mph to reduce the risk of driveline failure.
JL
