noisy flywheel
Old May 15, 2011 | 09:25 PM
bcbassking's Avatar
bcbassking
noisy flywheel
I am looking at getting my first psd. i am looking at a 1995 350 cc manual. the guy says it has a noisy flywheel and told me thats just the way new ones are is this true? what kinds of things should i look for in general befor buying a psd.
Old May 16, 2011 | 01:45 AM
richdawg's Avatar
richdawg
Welcome to FTE.
If the truck has had the Dual Mass clutch replaced with a single mass clutch kit, it is very common for them to make more noise.
Take a look at Steve Baz's page, some very good information here.
Steve Baz’s page:
Tips - Idea - Hints
Old May 16, 2011 | 09:21 PM
bcbassking's Avatar
bcbassking
what is the cost of a single mass kit?
Old May 17, 2011 | 05:42 PM
Jaaaaaaackman's Avatar
Jaaaaaaackman
A noisy flywheel is not the way these trucks are, if its a single flywheel the tranny most likely is loud and that is the way it can be, but if the truck still has the DMF look out cause its shot and will cost you at least 500 dollars DIY
Old May 17, 2011 | 07:10 PM
bcbassking's Avatar
bcbassking
i do not mind spending 500 if thats all it is. any thing motor wise i should be looking for in the way of problems?
Old May 17, 2011 | 07:48 PM
Jaaaaaaackman
Rust on a oil pan is a big bad, rust oil an oil cooler is bad too,,,,,,,, just lok over the truck real good
Old May 17, 2011 | 08:00 PM
rideracelivemx7's Avatar
rideracelivemx7
since its litteally not worth to buy a new dual mass fly wheel 99% of guys by a single mass kit and alot of trucks tend to get gear roll over from the tranny. this can be dampernd by adding an extra 2 quarts of oil threw the top of the shifter(remove cover)
if the truck has the stock dual mass fly wheel and its making that noise, it must be replaced asap, there have been reports of bad vibrations littearlly shearing off the tranny from the housing rendering the tranny junk. unless you know and extremely good tig welder
xtal_01
Jul 17, 2014 08:52 PM
MauleOne
15
Apr 1, 2012 08:07 PM
Ford59galaxie
Mar 28, 2012 08:08 PM
rudd21fan
13
Jan 26, 2011 03:02 PM
PAVEMENTMAN
16
Sep 9, 2009 06:07 PM
