Transmission cooler?
Old May 15, 2011 | 07:25 PM
dwhite1031's Avatar
dwhite1031
I have a 2007 F150 XLT 4.6L Supercrew. Pardon my ignorance, but is this the transmission cooler on my truck? Also, if it is, is it in addition to the usual transmission cooling lines that car makers run thru the radiator?
Thanks!
Old May 15, 2011 | 09:30 PM
Oldguy4's Avatar
Oldguy4
If you get down and crawl under your truck, you will see the oil lines coming from your transmission to that oil cooler. So, yes that is your transmission oil cooler. When you have a heavy duty oil cooler like that, they don't run the fluid through the radiator also.
Old May 16, 2011 | 04:19 AM
svt2205's Avatar
svt2205
The transmission cooler plumbing does go thru the radiator before the fluid flows thru the external cooler.
Holehawgg
Mar 23, 2015 09:06 AM
TGoodwin
17
Jun 21, 2014 10:39 AM
ccllud
Jun 17, 2014 11:17 AM
TGoodwin
17
Dec 10, 2013 04:29 PM
