Fuel Filter light
Old May 15, 2011 | 10:30 AM
smash fascism's Avatar
smash fascism
Fuel Filter light
I was driving home last night in the rain, prolly a 20 min trip and my fuel filter light came on. I checked the search and everyone seemed to experience a drop in power, mine didnt seem to be loosing power however. I do have a chip and I turned it up this morning and it didnt seem to be lacking, It did start harder than usual this morning. Any ideas? the fuel filter isnt that old and i just replaced the strainer in the front tank (which is the tank i use, the rear one is rotted)
Old May 15, 2011 | 11:23 AM
JamesHajek's Avatar
JamesHajek
Check it, could have got some bad fuel or something...
Old May 15, 2011 | 11:28 AM
Ken_C's Avatar
Ken_C
filter light comes on when theres a restriction. your filter needs replacing. or theres a pinch in the pick up line. find the restriction solve your problem. the pickup screen on our trucks can get pretty nasty.
Old May 15, 2011 | 11:51 AM
smash fascism
I have run a couple tanks of offroad in it, im changing the filter tonight. hope it works.
Old May 19, 2011 | 10:14 PM
smash fascism
Well I have changed the filter, changed the oil, and ran a couple tanks of fuel thought. light is still on, where should i start to look for this problem?
Old May 20, 2011 | 09:28 AM
Hussler's Avatar
Hussler
The sensor is just a switch. Unplug the wire going to it and the light should stay OFF. If it stays ON then that wire is shorting to ground somewhere. If everything is running OK then you may just have a bad sensor. At Ford they are kind of spendy but IH has them for about $25.
Here is a picture of the sensor, drivers side on the fuel filter canister ...
Old May 20, 2011 | 10:11 PM
makomark's Avatar
makomark
Though I can't speak to this particular design (we eliminated ours a while ago), pressure switches are notorious for having frequent failure rates (short lifetimes). Probably a good idea to verify adequate fuel pressure, under full load and acceptable pressure drop on the suction side. if they are good, the screen is cceptable and a pipe plug will let you buy a few extra gallons of fuel oil.
Old May 21, 2011 | 04:21 AM
Copedawg's Avatar
Copedawg
Have you drained the bowl yet?
X2 on the unplugging it. If you drain and change the fuel filter regularly you shouldn't need the reminder light, imo.
khaitan
28
Dec 3, 2016 08:38 PM
JimG1098
27
Aug 2, 2016 03:27 PM
264WSM
Oct 25, 2015 08:54 PM
Walt-1944
Jun 2, 2015 04:04 PM
Sailfast
40
Aug 22, 2009 04:06 PM
