suggestions for plugging/capping acoolant flange?
Old May 15, 2011 | 08:46 AM
carnut122's Avatar
carnut122
Running along the passenger side top of my 5.0 L SBF I have two coolant tubes that will feed the heater. One of the tubes has about an inch long flange for a hose to the EGR/throttle body that I will not be hooking up. As this flange will be under pressure, I was wondering what are your suggestions for capping/ or plugging it? I put a rubber vacuum cap on it about a year ago(along with several others on my intake) and they've all dry rotted to the point of falling off. So, I'm not confident in going that route again. Thanks!
Old May 15, 2011 | 10:54 AM
52 Merc's Avatar
52 Merc
I don't remember how far along the tube the egr nipple is, but if it's toward the end, it might be just as easy to cut it off short, removing the nipple, and run the rubber hose a bit longer. If it's in the middle, you could cut it out and replace it with a small section of hose, or replace the tube completely with a new piece without the extra nipple. They do look a lot cleaner that way than having big ol' ugly hoses running all over the top of your engine.
Old May 15, 2011 | 03:42 PM
jimprowse's Avatar
jimprowse
What i did on my 32 Ford , was machine up a plug/adapter , that was tapped for a pipe fitting, installed it in the freeze plug hole in the back of the right head , , and plumbed the line in there , cut's down one hose altogether ,,,,,,,,,,,,,,,,,, if running a "brand X " motor , you can trade the temp sender hole plug in the right head , for a fitting , and plumb coolant there , again a much shorter/neater hose run , just a thought ,,, Jim P ..
Old May 18, 2011 | 09:45 PM
carnut122's Avatar
carnut122
Th nipple is all the way up front by the alternator. The nipple by itself is stuck down by an injector, so it's kind of hidden. I just need a foll-proof way of sealing it. I'm considering squirting a glob of RTV into it and then capping it with one of those dry-rotting vacuum caps with a hose clamp around it.
Old May 18, 2011 | 09:48 PM
carnut122's Avatar
carnut122
When I first read this, I thought you misunderstood what I was trying to do. Now that I've read it again, that makes a lot of sense. I'll have to check where the tube originates.
Old May 18, 2011 | 10:45 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Pretty sure that earlier 5.0's that were carb'd used the same pipes but didn't have that nipple. Check with the boneyard. Otherwise, since it's steel, you could smash the nipple end flat and weld it shut.
Old May 20, 2011 | 07:16 PM
carnut122's Avatar
carnut122
I might give that a try.
Old May 21, 2011 | 10:58 AM
bobbytnm's Avatar
bobbytnm
Roast em' if you got 'em
They make freeze plug (weel plug) type caps in a huge variety of sizes. I'll bet you could pull the nipple out and find a cap that would press into its place.
I had to do that with the A.I.R. fitting on the heads of my Caddy engine. The AIR tubes came out of the heads and left an approx 9/16" hole. I went my local machine shop with the precise measurement and they fixed me right up. Clean and simple
Bobby
Old May 21, 2011 | 07:03 PM
carnut122's Avatar
carnut122
Bobby
It's probably about 1/4" od. Do they make the plugs that small?
Old May 21, 2011 | 07:15 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Stick a screw in it and braze it in. Might even be able to tap it and screw it in with Loctite.
Fat Diesel
195
Aug 7, 2020 08:01 AM
prorad
Nov 15, 2016 11:32 AM
Occidental
Oct 19, 2016 06:45 AM
meck1
1983 - 2012 Ranger & B-Series
Aug 5, 2016 04:25 AM
Glaser67
Jul 13, 2016 06:24 AM
