would anybody happen to have any pictures or wiring diagrams on the power locks? the previous owner had a viper alarm system installed and then it stopped working so i removed it. i need it from where it comes out of the drivers side door. total of 4 wires. thank you.
I may be wrong, but should be a common ground.....And the other 3, should be the positives for the windows, and the door locks....Color codes...Have no idea
I was looking at the diagram and was wonder where I would find the C213 wire connector? I went through my 92 F150 lock system and did a lot of voltage and switch testing to determine why is wasn't workin. I determind that the Pink/yellow wire that goes from the driver's side (LH) it's making a connection to the pink/yellow wire on the passenger side (RH). I ran an open wire from pink/yellow driver side to pink/yellow on the passanger side and then everything worked fine. So I assume I have a broken wire on a grounded short somewhere. I have a 92 shop repair manual, but the door lock wiring diagram is different from the one you posted. It doesn't show the C213 connection. On your link the C213 has a vertical dash line, which I assume means all the wires pass through the C213. In my 92 shop manual, the drawing has four dashed lines. Not sure how to post a picture or PDF of my schematic.
