I have a 78 F150 with a 351M. It died while idling and I had to tow it home. The battery is older, but has a full charge, and I got nothing when I turned the key. I have replaced the starter, solenoid and cable between the two. Now I get rapid clicking in the solenoid. It did turn over twice at one point and I thought it was fixed, but it's back to the clicking again. Is this a ground issue, and if so, where do I go from here?
Grounds are usually the first thing to check. Neg batt cable should go directly to block. Solenoid must be grounded for it to work, a lot of times just a sheet metal mounting screw isn't enough.
My 79 was actiong the same, it did turn out to be the ground to the block.I replaced everything before the ground wire, before I figured it out though. Hope this helps.
I agree, check the grounds, then if worse comes to worse, you might need to check your starters teeth. If they are rounded, check your flywheel. It might be time for a new one.
Thanks for the responses, but I have had a breakthrough to a new problem.
My brother had me try turning the crank with a socket and breaker bar to see if the starter gear had bound up. I did, and the truck then turned over...until after several tries to get it started, it went back to clicking again. So now I'm thinking either my new starter is defective or my flywheel is junk. I'm sure hoping for the former, not the latter. Any comments to this? (400inatruck- I had no idea where you were going with your post- now I do).
Reason: Add text
Take a jumper cable and use positive wire to jump from pos batt to starter side of relay. Neg side to batt and engine ground. If engine turns over, you know it's not the starter.
I had the flywheel problem happen on a '78 f250 with a 400 in it. We had to go to Oreilly's 5 times for new starters(we kept grinding the teeth off), and we went for 2 solenoids, and I looked at the flywheel, and it looks bad. I am planning on taking it out anyhow. Speaking of it, Any ideas on how to unlock a motor? It froze due to setting still for 3 years. I tried transmission fluid, wd 40.
@gfw1985 just use the positive side of the jumper cable. the starter is already ground. The ground cable(if the battery is hooked up) goes the engine mount anyhow.
The reasoning behind my post was to get to make sure he has a good ground for the test. Next step, providing it works, is remove the neg jumper. If it quits working his ground is bad.
After all that, it turns out it was a bad ground. I replaced both battery cables (the negative was worse than I thought), now it starts again. I had been using jumper wires and my multimeter, so I didn't think it would help. Thanks all for the tips and tricks! My truck lives again!
