CMP Recall
Old May 13, 2011 | 12:28 PM
Oslo's Avatar
Oslo
CMP Recall
Today Ford sent me a letter saying records show my truck has not had the 07S57 - Camshaft Position (CMP) Sensor Inspection / Replacement performed yet ! If I have not had problems yet should I be concerned about this and which color sensors are good and which colors sensor are bad. Also do they let you keep the old parts as spares. Thanks Oslo
Old May 13, 2011 | 12:32 PM
Copedawg's Avatar
Copedawg
I got that same letter...Mine has been replaced since day 1 (a few times). Will they still replace it, even though it is not origanal?
Old May 13, 2011 | 12:41 PM
1973dieselhighboy's Avatar
1973dieselhighboy
yes if it has a open 07s57 the sensor gets replaced with the updated ones which are gray with a silver bracket
Old May 13, 2011 | 12:44 PM
Oslo's Avatar
Oslo
Just got off the phone with dealer said next week anytime take about 45 min. the letter says inspection/replace so who knows.
Old May 13, 2011 | 01:17 PM
Copedawg's Avatar
Copedawg
So you think if I have replaced the origanal already....they won't replace it? even though I have not taken advantage of the recall?
Old May 13, 2011 | 01:35 PM
ccarrier's Avatar
ccarrier
45 mins??!!?!? do what i did, raise a big stink about them taking your truck in the garage for so long and theyll do it in the service lane in less then 10 mins!
Old May 13, 2011 | 01:41 PM
ccarrier's Avatar
ccarrier
they will replace it. mine had been replaced when i bought the truck and they still replaced it.
Old May 13, 2011 | 11:47 PM
STIHL021's Avatar
STIHL021
Yup got that letter too, I had a problem with my truck awhile back and replaced it with an auto zone one (before I knew to go to ford for it) and my dealer wanted me to drop it off for a whole day. It took me about 15 minutes so I think its a rip off to leave it there all day
Old May 14, 2011 | 12:28 AM
BuckHammer's Avatar
BuckHammer
45 minutes for a CPS replacement?
Old May 14, 2011 | 09:32 AM
Oslo's Avatar
Oslo
Just got back from the dealer 2 Recalls performed 07S57 CPS replacement.
09S09 Speed Control System Modifacation (Installed Universal Fused Jumper Harness).
Both took less then a .5 HR. very pleased. New CPS part # is F7TZ-12K073-B
New Wire Assembly part # is 8W7Z-14A411-C
Old May 15, 2011 | 05:49 PM
bigjim31's Avatar
bigjim31
had the same 2 recalls done and it took the 4 hours but that also included a full inspection of the truck and i found out the seals in my oil cooler are leaking.
Old May 15, 2011 | 06:37 PM
427 fordman's Avatar
427 fordman
No big deal there, I haven't done it but its not a big job. There's help here if you need it.
Welcome to fte bigjim
Old May 15, 2011 | 11:33 PM
ReFlectiveMan's Avatar
ReFlectiveMan
I started having problems with losing the Ford ones every 3-5K miles, so at a suggestion I switched to the International one about 35K miles ago and haven't had a problem since. They look EXACTLY like the current Ford one, one would think they should be the same but apparently they arent.
Current International part number is 1876735c91. My local International Dealer charged me $19 for it.
Old May 16, 2011 | 10:36 PM
bigjim31's Avatar
bigjim31
oil cooler
thanks guys i did alot of reading on this forum and got alot of tips on fixin up my ride. i ordered the oil cooler kit from diesel o-rings.com and will be doing it this weekend.
Old May 17, 2011 | 06:52 AM
427 fordman
Don't be afraid to start up a new thread if you need some help bigjim. Good luck with your oil cooler project.
