Sponsored by: Real Truck
once in a while ALL windows stop working at same time
Old May 12, 2011 | 10:12 PM
PPrash's Avatar
PPrash
About every 5<SUP>th</SUP> time I drive my truck ALL windows (4 door crew cab) will not work. No way no how do they start working until I park it and the next time I start it they likely will. I cant shut it off and back on to roll them up either when it happens. They all work fine when this is not happening too. Any ideas?<?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
Old May 14, 2011 | 03:58 PM
swengle's Avatar
swengle
I had the same thing happen on my 2005 F250. I noticed it would occur only when someone had been sitting in the back (crew cab) - but not always. Turns out the power window switch for the right rear window was sticking in the "up" position. Window would roll up and then the motor would stall, and stay stalled, eventually causing the power window circuit breaker to open, killing power to all the windows.
The power window circuit breaker is the silver thing stuck into the fuse panel under the steering column. Next time the windows crap out, touch the breaker with your fingers - it will be HOT! Once it cools down (takes awhile) then the windows will work again, but only for a short time (seconds) if the switch is still stuck.
Find which switch is sticking and repair/replace. Then all will be well again.
Steve
outlawspeeder88
Mar 3, 2015 06:00 PM
38-72
17
Nov 3, 2011 07:10 PM
jacobsk
May 8, 2006 12:58 AM
tvulcan
Jun 2, 2004 02:47 PM
