Gas Tank
Old May 12, 2011 | 07:20 PM
Will Chiello's Avatar
Will Chiello
Gas Tank
I have a 1992 F150 with two tanks and want the front tank out. What fuel lines do I have to plug up, in order for this to work. -Thanks
Old May 13, 2011 | 11:53 AM
whisler's Avatar
whisler
I have the same question about an "89 F250, except that i need to remove a badly rusted rear tank. I'll be watching to see what info you get.
Old May 13, 2011 | 05:27 PM
subford's Avatar
subford
Just replace your DFR with a STR. Its plug and play.
Old May 13, 2011 | 05:28 PM
subford's Avatar
subford
You need to plug both the supply and return lines that you take off the front tank.
Old May 13, 2011 | 10:25 PM
whisler's Avatar
whisler
Not sure what you mean by DFR and STR. Sorry!
Old May 14, 2011 | 06:22 AM
subford's Avatar
subford
These only apply to 1989 an older MFI trucks like yours.
DFR : Dual Function Reservoir (Dual tank Selector Valve).
STR : Single Tank Reservoir (Single Function Reservoir).
DFR is mounted on the frame:
STR is also mounted on the frame at the same location:
Old May 14, 2011 | 03:40 PM
whisler's Avatar
whisler
Awesome pictures and diagrams. Thanks a lot.
Iantiler
17
Feb 8, 2014 01:30 AM
stopp429
Feb 15, 2013 06:42 PM
iontkendall
Dec 21, 2010 04:53 PM
breedo99
13
Mar 25, 2010 09:07 PM
sourpuss
Feb 8, 2005 10:02 PM
