98 Ranger problems
Old Mar 23, 2003 | 08:38 AM
flatliner's Avatar
flatliner
Question 98 Ranger problems
I'm having a couple problems with my Ranger that I figured you guys could help me out with. I've got a '98 XLT, ext. cab, 4X4 with the 4.0. When the truck is idling, it runs fine and it runs fine at highway speeds. The problem is when I go up a hill or something that makes the rpm's drop a little, the engine cuts out sporadically. Then the trans. will downshift and eveything is OK until I get to the next hill. I changed the plugs and wires about 6000 miles ago. Last night I tried to change the fuel filter but I couldn't figure out how to get the lines off of it. How do those darn things come off?
Old Mar 23, 2003 | 10:03 AM
Rockledge's Avatar
Rockledge
98 Ranger problems
If you read through this thread you'll find some help:
https://www.ford-trucks.com/forums/s...ht=fuel+filter
Old Mar 23, 2003 | 10:32 AM
flatliner's Avatar
flatliner
98 Ranger problems
Dang, I didn't know you had to have a special tool. How much is one and where can I find it? Whatever happened to good ole' hose clamps?
Old Mar 23, 2003 | 05:11 PM
Rockledge's Avatar
Rockledge
98 Ranger problems
....a special tool. How much is one and where can I find it?
I'm pretty sure any parts store will have one. The plastic ones are about 9-10 bucks (I heard) and the metal ones are about double that.
Old Mar 23, 2003 | 08:22 PM
saintthomas's Avatar
saintthomas
98 Ranger problems
i just did the smae job two days ago. I got the tool at Advanced for $4.00. I still had a little problem getting it to fit on there. I had to file a little off the tip. Not hard to do at all. And I am by no means a mechanic.
Old Mar 24, 2003 | 08:54 AM
WXboy's Avatar
WXboy
98 Ranger problems
Flatliner...I had the exact problem you are describing a few weeks ago. I changed my plugs, wires, fuel filter, and air filter. Now the problem is gone, AND I have gained about 2 miles per gallon. I am very pleased.
The fuel filter tool cost about 25 bucks at NAPA, but I got the metal one because I heard the plastic ones can break easy.
(I also had my transmission fluid flushed and refilled a few weeks ago to solve a slipping problem I had with the tranny).
Old Mar 26, 2003 | 07:05 AM
flatliner's Avatar
flatliner
98 Ranger problems
Thanks for the info guys. I think I'm gonna drop mine by the local shop and let them put the filter on and see if they can find my other problems as well. I don't know if a computer diagnostic will do any good since the "check engine" light isn't on.
iracekx
28
Nov 17, 2014 06:11 PM
1998Ranger25L153CID
Jun 10, 2008 08:56 PM
RangerPilot
Dec 22, 2007 09:28 AM
reed1977
Jul 12, 2005 11:52 PM
5.0stang
16
Apr 21, 2005 12:20 PM
